Author Topic: Car leaning. Need help.  (Read 4856 times)
Offline smallblock
« on: July 14, 2014 - 06:28:42 PM »
I'm loosing my mind and am about to call it quits on this car. I have a 74 Challenger and the rear driver side sags very bad. It was like this when I bought it and had air shocks on it to level it up. I always figured it had a weak or broken leaf spring. I ordered the super stock leaf springs from Summit and replaced the one I thought was bad and its worse! It sits right on the tire as I have a pretty wide set on the back. I then bought a set of those extended shackles and put it on with the new spring and it still sags!!!??? So far I haven't touched the passenger side and it still sits higher. I'm lost. What could cause this?
Re: Car leaning. Need help.
« Reply #1 on: July 14, 2014 - 06:41:40 PM »
Well, my first thought is the leaf springs, especially if you have a transplanted big block.
How does the front look? Is the passenger's side higher than the driver's side? Do you have new shocks on the back? What size tires in the rear?
Offline 1 Wild R/T
« Reply #2 on: July 14, 2014 - 06:55:33 PM »
Could be a weak torsion bar.... Or a twisted frame.. Unfortunately I've seen more twisted frames of E bodies than you'd believe.. Dukes of Hazard antics aren't kind to these cars...
Offline Jesus H Chrysler
« Reply #3 on: July 14, 2014 - 07:03:55 PM »
Try swapping sides with the springs to see if that changes anything.  That would decide if it's spring related, or frame/hardware related.  Also, try to keep springs in pairs, meaning don't put one XHD spring and one Super Stock spring on the car.  While you're in there, look for signs of bent or tweaked frame rails.  Wrinkles, pinching or asymmetry can be signs somethings not aligned right.  For what it's worth, I and many others have had NO luck with Mopar rear springs when it comes to saggy butt syndrome with these cars.  From what I hear ESPO and a few others make good springs, I just have no personal experience with them.
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #4 on: July 14, 2014 - 08:04:39 PM »
Are the air shocks still in it? If you have a level garage floor put it on jack stands and see if the frame is level front to back, height of the floor etc. Can you read the part numbers on the leaf springs that were in it, maybe they are wrong for the car, wrong sides ???
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline torredcuda
« Reply #5 on: July 14, 2014 - 08:05:40 PM »
Also check the torsion bars and mounts as it could be a problem up front.  :dunno:
Jeff
Offline Edison1970
« Reply #6 on: July 14, 2014 - 08:12:36 PM »
Mine did the same thing.  I put new torsion bars in and problem resolved.  I would first re-adjust the torsion bars.  Adjust them equally on both sides.  See what happens.
« Reply #7 on: July 14, 2014 - 09:03:28 PM »
Agree on the front torsion bars. Make sure they are set up level on the front. Adjusters on each side should stick out about the same amount.
« Reply #8 on: July 15, 2014 - 12:10:13 AM »
:iagree: x 3
Offline dutch
« Reply #9 on: July 15, 2014 - 02:12:30 AM »
make sure the car is on a super straight concrete floor when measuring. It drove me crazy adjusting mine ,thinking the floor was level.... it had a small dimple and screwed up all measurements.
*** Bart ***
Offline dougs bs23
« Reply #10 on: July 15, 2014 - 03:02:24 AM »
Also check all you frame alignment points to make sure the body's not twisted
Offline ChallengerHK
« Reply #11 on: July 15, 2014 - 08:45:39 AM »
Somebody posted a long time ago that the front and rear spring eyes are angled so that the springs are closer togethe in the front than in the back. If so, you might be able to get them to fit in a side-to-side swap in the short run for testing, but in the long run you're going to want to have them mounted on the correct side.
- Han Solo, Star Wars
Offline smallblock
« Reply #12 on: July 15, 2014 - 11:22:46 AM »
Thanks for all the help! What is the best way adjust and set the tortion bars? Visually everything looks good under the car.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #13 on: July 15, 2014 - 11:53:50 AM »
Measure your fender height on both sides, either from the ground on a flat surface or center caps to lower rim.  There is a bolt that is sticking out the bottom of the a arms - clockwise to raise the car, counter clockwise to lower the car. After a few turns, bounce the front end and on both sides and re-measure.  You should be close, within a an 1/2" or so.  Once you get it to the right height, take it out for a quick spin and then re-measure.  You want to make sure your front tires don't rub when hitting bumps.  This will also change the camber of the tires so you will need to get an alignment.
« Reply #14 on: July 15, 2014 - 12:10:00 PM »
Make that adjustment with the front tires off the ground. If you adjust with the weight on the tires the adjusting bolts can strip.
