Author Topic: Car leaning. Need help.  (Read 4854 times)
Offline torredcuda
  • Epping NH joined 11/23/03
Re: Car leaning. Need help.
« Reply #15 on: July 15, 2014 - 04:58:02 PM »
It`s better to measure to a point on the frame rail as the fenders are bolted on and can be adjusted up/down. There are specs somewhere for it.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline torredcuda
« Reply #16 on: July 15, 2014 - 05:04:35 PM »
The factory measurements are taken from the ground to point a) the bottom of the torsion bar socket where it goes through the control arm, and b) the bottom of the lower ball joint.  Formula is measurement a - measurement b =1 1/8". You keep changing your ride height until your variables equal the  1 1/8 distance
Jeff
Offline smallblock
« Reply #17 on: July 15, 2014 - 05:39:26 PM »
I understand how this raises the front of the car but how does it raise the rear?
Offline torredcuda
« Reply #18 on: July 15, 2014 - 05:42:40 PM »
Just making sure the front is level so you know the problem is in the back. Did you take the shocks out?
Jeff
« Reply #19 on: July 15, 2014 - 05:46:42 PM »
The assembly tolerances on these were so loose that things could be off quite a bit from the factory. Its possible everything is exactly where it should be, you  just have tolerance stack up that makes it worse than it appears.
You want to adjust the driver's side torsion bar to offset the height on the passenger side rear.
Think of it as a diagonal teeter totter to understand how changing the front effects the rear.
Offline smallblock
« Reply #20 on: July 15, 2014 - 06:22:12 PM »
The shocks are still on but the air lines are off so there's no air in them.
Offline torredcuda
« Reply #21 on: July 15, 2014 - 07:28:43 PM »
Sure one is not stuck? I`d remove them completely just to rule them out.
Jeff
Offline soundcontrol
« Reply #22 on: July 15, 2014 - 07:30:54 PM »
Good info! Always wondered how to set these. Does it have a lot of effect on your wheel alignment if you do adjustments?
/ Ken
topic=108917.new#new
Offline smallblock
« Reply #23 on: July 15, 2014 - 09:10:58 PM »
OK , I had a little time tonight. I measured both sides up front from the edge of the fender to the top lip of the rims. The passenger side was an inch and a half higher. I have no idea how i never noticed it. The rear is very noticeable but i never seen the front. I looked at the tortion bar adjustment bolts and they looked like they were dead even in terms of adjustment. I jacked up the front passenger side as the drivers rear is sagging and since the driver side being lower never rubbed I turned the adjustment bolt out two full turns at a time then lowered the car and bounced it up and down several times and remeasured. I ended up doing this six times, turning the adjustment bolt out twelve times until both sides measured the same and bingo the rear end sits even. So I guessnow iI'm wondering why the front end is adjusted so different side to side. I'm imaging the tortion bars are weak and need replaced?
« Reply #24 on: July 15, 2014 - 09:23:59 PM »
Take it for a drive an re measure  ;)  Then get a front end alignment
Offline Gus cuda
« Reply #25 on: July 16, 2014 - 06:52:39 AM »
Yea mine was a little outta whack what I first got it also. Adjusting the torsion bars took care of mine. Hope that does it for yours. I agree with the others, get rid of those air shocks! Good luck
« Reply #26 on: July 16, 2014 - 07:01:14 AM »
Mine too, its 1" lower on the driver side rear, got those horrible airshocks also. I just assumed it was worn out leaf springs. Got a new Firmfeel stage 3 kit in the garage though, all new springs and shocks.
/ Ken
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #27 on: July 17, 2014 - 04:22:55 PM »
 :iagree:  Nothing good about air shocks.
Offline MTS-Challenger
  • Vanishing Point - "Catch Me If You Can"
« Reply #28 on: July 18, 2014 - 02:04:47 AM »
This may help
http://www.cuda-challenger.com/cc/index.php?topic=29560.0
1970 Challenger R/T 440
« Reply #29 on: July 18, 2014 - 06:42:21 AM »
It has a large effect. You really need to set up the ride height where you want it b4 you get an alignment.
