Author Topic: Car leaning. Need help.  (Read 4855 times)
Offline soundcontrol
Re: Car leaning. Need help.
« Reply #30 on: July 18, 2014 - 08:58:02 AM »
It has a large effect. You really need to set up the ride height where you want it b4 you get an alignment.
Ooops!   :screwy:
/ Ken
topic=108917.new#new
« Reply #31 on: July 20, 2014 - 07:01:33 PM »
As you found out the front T bars are much stiffer than the rear leafs so adding extra load on the front will tweak the rear more than the front .
 The T bars will have #s cast into the ends so if you clean the rear you should be able to see the #s , typically you will have 77 / 78  T bars odd being the left side , if the adjustment bolts are off a bit but the car rides fine , no need to swap T bars .
 All the advice here is good , make sure you have the ride height where you want it , do not get it aligned to factory specs , they are for Bias ply tires , max the caster & 1/2* negative camber & 1/16" toe in & you are good to go
