Author Topic: Light weight hood springs ??  (Read 3044 times)
Offline 69CHARGERMD
« on: July 14, 2014 - 08:43:03 PM »
Anyone know where I can find some lightweight hood springs for my TA fiberglass hood ??
Any vendors or sources that have these ??
Thanks for any help.
Doug.  :cheers:
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline publicbottle
Re: Light weight hood springs ??
« Reply #1 on: July 14, 2014 - 10:03:22 PM »
i got mine from resto rick.....however just finished putting on my t/a hood from stinger firberglass (aar fibreglass) hood still bowed within a day or two, took the springs off completely and using a hood prop rod now.
Offline 69CHARGERMD
« Reply #2 on: July 14, 2014 - 10:33:16 PM »
Thanks Public,,,,I also have a new AAR hood,,nice piece,,,,
I saw a lot of TAs and AAR at Carlise and took note of their springs
I might try VFN for some springs if they have them
Too bad AAR doesn't have them.
Thanks
Doug  :2thumbs:
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
« Reply #3 on: July 15, 2014 - 12:00:12 AM »
  :iagree:  don't waste your money, mine bowed too!  I bent up a simple prop rod that goes in the existing holes in the hinge .
There are more than one manufacturer of the springs for the T/A hood. I tried them both, none of them worked, they didn't hold up the hood very well and bowed the hood
Offline Travis72
« Reply #4 on: July 16, 2014 - 10:11:17 AM »
Based on a tip I read about on here, I used trampoline springs (10" long) that I bought on eBay for 5 bucks.  I would either try that or the prop rod first.
Travis
72 Cuda
Offline 69CHARGERMD
« Reply #5 on: July 19, 2014 - 06:51:11 AM »
Thanks Travis !
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline AARuFAST
  • AARuFAST
« Reply #6 on: July 28, 2014 - 12:13:07 AM »
I use turn buckles
ACE hardware sells different sizes.
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline 69CHARGERMD
« Reply #7 on: November 09, 2014 - 05:20:23 AM »
Just some follow up.....
I ended up getting the light weight hood springs from Year One ( for the Challenger TA hood )
They worked out great with the TA hood I am using from AAR Fiberglass......no bowing issues,,,,FYI
Doug :woohoo:
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #8 on: November 09, 2014 - 10:49:19 AM »
Anyone using a spring in the front to help pop open the hood a little?  I know you are supposed to lift the hood from the base corner under the scoop, but seems like a lot of stress until I can get my hand under the front to help lift the hood.
Offline javakm70cuda
« Reply #9 on: May 31, 2017 - 02:47:48 PM »
I used a springs from a metal futon bed with my AAR VFN fiberglass hood. Works perfect and they have been on there 7 years now. Holds hood right up. Original brackets and 2 springs on each side taken from one futon bed. the all metal kind college students usually use.
Cheap and easy
