Author Topic: Electric Fuel Pump  (Read 4369 times)
Offline CudamanTom
Re: Electric Fuel Pump
« Reply #15 on: July 17, 2014 - 10:29:03 PM »
the regulator and return line seem like kinda a pain,
There isn't a return line, just a regulator. Once the reg is set (one time), your good to go.
At least with a Mallory 4110 that I use.  :bigsmile:
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline cudabob496
« Reply #16 on: July 18, 2014 - 03:26:16 AM »
sounds good!
https://www.youtube.com/watch?v=3sqAjdBndG8
http://www.hotrod.com/featuredvehicles/hrdp_1007_david_freiburgers_1970_dodge_super_bee_unearthed/viewall.html
« Last Edit: July 18, 2014 - 04:44:10 AM by cudabob496 »
2011 Kawasaki Z1000
Offline 71chmark
« Reply #17 on: July 19, 2014 - 12:47:18 PM »
 I have a Mallory that I bought sometime n the early 90s. I can't remember the model but I don't use a regulator with it and it feeds my 440 just fine.
I may be schizophrenic,
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #18 on: July 19, 2014 - 01:43:15 PM »
When I replaced all my fuel lines I put in a return behind my block with a Mallory 4110 mounted under the trunk and no regulator, just a pressure meter that reads 7 psi consistently.
« Reply #19 on: July 19, 2014 - 03:30:41 PM »
Bad placement for the fuel line !!
Any clutch or converter / flex plate issues & the line could get cut !
