Author Topic: Quality voltage regulator?  (Read 1734 times)
Offline torredcuda
  • Epping NH joined 11/23/03
« on: July 18, 2014 - 04:42:59 PM »
Anyone have a source for a good voltage regulator made somewhere other than China? I don`t care too much about looking original just a quality part.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline DocMel
Re: Quality voltage regulator?
« Reply #1 on: July 18, 2014 - 06:41:05 PM »
Most of them are made in China or overseas.  Go to NAPA or Car quest, see if they carry US made ones.  But unfortunately, I dont beleive there is much of a dif.  Its a very simple part
« Reply #2 on: July 18, 2014 - 07:52:22 PM »
Mopar lists 2 , the repro black with original part # & the blue more accurate regulator which controls the voltage to tighter limits .
 Roseville or Mancini should have both
« Reply #3 on: July 18, 2014 - 10:42:54 PM »
I bought one at Mancini's ..... $20? So far so good ( black one)
Offline torredcuda
« Reply #4 on: July 20, 2014 - 03:52:25 PM »
Well it urns out it`s not the voltage regulator or the alternator, not sure what`s causing the charging problem now???   :clueless:
Jeff
« Reply #5 on: July 20, 2014 - 04:10:45 PM »
Did you add anything electrical? Doesn't take much to use up the amperage the stock alternator puts out?
« Reply #6 on: July 20, 2014 - 07:15:15 PM »
simple circuit , power to reg & field blue wire , green wire grounding field to reg which controls the ground to limit charging , if the reg & alt are OK then you have a number of issues , connations at both bulkhead plug , ammeter , or bad ammeter gauge , or the alt cannot put out enough power to supply everything so you may need a higher output alt , if you do go higher than 60 amps I recommend a bypass from the alt directly to the bat connection on the start relay on the left inner fender ,
« Reply #7 on: July 21, 2014 - 10:41:06 PM »
Is your wiring factory original? Or have you modded it?
Offline DocMel
« Reply #8 on: July 23, 2014 - 10:06:47 AM »
triple ensure that your regulator has a good and solid ground or the charging system will never work. The location and means that the reg is mounted is a pretty poor ground , and over the years it becomes pretty bad.
I went the extra route of having a small ground strap added
Ask me why......:(
