Author Topic: 73 cuda front sway bar point up or down?  (Read 1773 times)
Offline crash340
« on: July 18, 2014 - 09:52:06 PM »
Team,
am putting my front sway bar back on, though I had a photo of it but dont seem to, anyway, the bar bends around and makes its way back to the LCA it has a slight curve in it, when its in the car, should it curve up or droop down as such?? my memory tells me it should droop not curve up... does that make sense?
Greg
73 Cuda
Brisbane, Australia
Offline anlauto
Re: 73 cuda front sway bar point up or down?
« Reply #1 on: July 18, 2014 - 10:03:59 PM »
Awwww..My favorite pet-peeve.....A lot of people install them wrong.
Your sway bar should be frowning, NOT smiling :bigsmile:...curve up !  Sway bar links have the nuts on top. Sway bar loop bolts point down while the loop bracket bolts point up. :2cents:
« Last Edit: July 18, 2014 - 10:06:05 PM by anlauto »
Offline crash340
« Reply #2 on: July 18, 2014 - 10:17:50 PM »
thanks Alan, that is exactly how it came off my car with the bolts in that order and direction, I have just found the photo i took.
Greg
73 Cuda
Brisbane, Australia
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: July 19, 2014 - 02:21:09 PM »
Alan, how do you get a swaybar to smile instead of frown?
There is no way I could have gotten it together without the bar pointing down.
Offline anlauto
« Reply #4 on: July 20, 2014 - 12:44:33 PM »
Flip the bar over and put it in the other way....then it will smile :2cents:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: July 20, 2014 - 12:55:49 PM »
That's my point, maybe when the kmember is on the car you cannot because I couldn't slip it through the kmember the wrong way cause it just wouldn't go.
Anyway, if it's pointing up you would have to shorten the endlinks to make it work.
Offline anlauto
« Reply #6 on: July 20, 2014 - 02:59:18 PM »
The bar fits through the K member either way. End links fit either way. :2cents:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: July 20, 2014 - 10:05:53 PM »
Heh we must be miscommunicating but no biggee.
Offline anlauto
« Reply #8 on: July 21, 2014 - 08:24:09 AM »
Here's one that is installed incorrectly...It's smiling for you :bigsmile:
