Author Topic: what kind of antifreeze?  (Read 1595 times)
« on: July 22, 2014 - 05:11:23 PM »
Ok with new technology all around us what about antifreeze? With aluminum rad's , heads and intakes should we be using something different than the old green stuff? What about the GM "Dex cool" orange stuff? I read about it on the net causing head gasket issues?
Fill me in?.....
Offline jimynick
Re: what kind of antifreeze?
« Reply #1 on: July 22, 2014 - 10:55:36 PM »
Brad, stay away from that pink junk! Prestone is good and just read the bottle for aluminum compatibility; they're virtually all good with it.  :2cents:
« Reply #2 on: July 23, 2014 - 08:01:53 AM »
I just use Prestone green & not the 50/50 mix as why pay 80% of the cost when 1/2 is water ?
 Antifreeze tech has kept up with alloy engines .
 Long life red coolant never seems as good
 the best option is probably Evan waterless but you need 4 jugs @ $40 / gallon
Offline Ravage
  • 1974 318 'Cuda
« Reply #3 on: July 23, 2014 - 08:10:03 AM »
Classic Prestone has always been good to me  :working:
"I flipped off a box of kittens once..." (Tycho on being evil)
Offline ammo
« Reply #4 on: July 23, 2014 - 08:29:47 AM »
Readily available anywhere on a road trip if you need it.
1973 dodge challenger
Offline shadango
« Reply #5 on: July 25, 2014 - 08:01:15 AM »
:iagree:  Yep.  That or Zerex green.  My grandad swore by Zerex.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #6 on: July 25, 2014 - 10:08:25 AM »
 :iagree:  Tried and true.
Offline RCCDrew
« Reply #7 on: July 25, 2014 - 12:07:44 PM »
I live in a warm environment. (South Texas). I prefer to use a corrosion inhibitor instead of antifreeze.
