Author Topic: Plum Crazy T/A in Australia.... here goes...  (Read 32869 times)
Offline whitewatersky
Re: Plum Crazy T/A in Australia.... here goes...
« Reply #75 on: March 25, 2015 - 07:36:28 AM »
Plum Crazy auto T/A Challenger
« Reply #76 on: March 25, 2015 - 07:39:16 AM »
« Reply #77 on: March 25, 2015 - 08:10:35 AM »
« Reply #78 on: March 25, 2015 - 08:27:09 AM »
« Reply #79 on: March 27, 2015 - 09:51:48 PM »
Interesting there's hex head screws on the cowl vent screens :clueless:
what's it meant to have Alan ?
Offline anlauto
« Reply #80 on: March 27, 2015 - 10:50:30 PM »
Usually in 70 they were a special Phillips head, shouldered screw...They changed to hex head in 1971...
« Reply #81 on: March 28, 2015 - 12:28:21 AM »
Thanks mate. I'll look thru what we have from the tear down. Also look for other pics I took before removal. One vent screen is busted. Could be one was replaced sometime in the past. I have a new vent ready to install so will use correct screws
« Reply #82 on: April 01, 2015 - 08:39:52 PM »
Really progressing things here with the T/A
I'm contemplating whether to re-chrome, replace or simply polish these up. Only a coupla minor dents thankfully.
Does anyone have a recommendation for the replacement option? Best quality, NOS availability etc
Offline anlauto
« Reply #83 on: April 01, 2015 - 09:24:33 PM »
Looks good...Transmission cross member bolts are in backwards :2cents:
« Reply #84 on: April 01, 2015 - 09:45:31 PM »
"Transmission cross member bolts are in backwards"
thanks Alan - I appreciate the tips with these things.
the trans crossmember seemed to be painted black. but then the black coating came off with kerosene when Ian was cleaning it up.
either it was thoroughly coated in dried oil n gunk that looked like a coverage of paint, or the paint job was poor. kero shouldn't have removed the paint.
thinking we'll just clear coat it
or should it be black ???
« Last Edit: April 01, 2015 - 09:47:44 PM by whitewatersky »
Offline anlauto
« Reply #85 on: April 01, 2015 - 10:36:13 PM »
Should be black :2cents:
« Reply #86 on: April 01, 2015 - 10:37:01 PM »
ripper - thanks mate
 :cheers:
Offline YellowThumper
  • I left the snow for this?
« Reply #87 on: April 02, 2015 - 04:40:40 PM »
I also appreciate the 2c additions.
Read one earlier that made me review front sway bar and all associated attaching bolt and hardware orientation.
« Reply #88 on: April 27, 2015 - 11:03:11 PM »
Time for Carbys to go on
Should this have a plate / pan across the bottom of the valley cover?
There wasn't one on it
« Reply #89 on: April 28, 2015 - 08:37:28 AM »
yes it keeps the oil off the intake where the heat crossover goes though the intake , I would suggest just blocking the heat crossover port where the intake meets the head instead
