There have been issues with the reproduction valves. Something inside wasn't machined correctly which causes the brakes to stay applied. I don't know if they got the issue fixed or not. You can get them from Fine Lines.
Personally, I would disassemble the valve and soak it in EvapoRust. I don't think there is an O-ring kit available but you should be able to find some at a parts store. If the original ones are still good, I'd reuse them. There isn't much to these valves. Just be careful taking them apart. I've got an exploded view of the valve but it's not on this computer. I'll see if I can find it online.
