Author Topic: which axles?  (Read 798 times)
Offline aris_unlimited
  • Project in full swing
which axles?
« on: July 23, 2014 - 07:57:32 AM »
Got a rear disc conversion kit for my 74 satellite. Has directions for 1 piece and 2 piece axles. How do I tell which I have?
Cuda is gone :(
74 satellite, daily driver/project now
Offline anlauto
Re: which axles?
« Reply #1 on: July 23, 2014 - 08:05:31 AM »
Are they referring to the axles or axle bearings ? :clueless:
Re: which axles?
« Reply #2 on: July 23, 2014 - 08:17:51 AM »
Directions are quite vague lol. It's an 8 3/4 rear if it makes any difference.
Cuda is gone :(
Re: which axles?
« Reply #3 on: July 23, 2014 - 09:04:49 AM »
The kit is from summit racing, says it's an 8 3/4 disc conversion kit. Wonder if they thought some might put it on an 8 3/4 front axle. Meaning if it had cv axles (rather than a solid axle), some might consider it a 2 piece axle shaft.
Cuda is gone :(
Offline Jesus H Chrysler
Re: which axles?
« Reply #4 on: July 23, 2014 - 09:58:55 AM »
To my knowledge they never made a 8 3/4 CV axle or anything exotic like that.  Read the instructions for each and see what the difference is between the one piece and two piece setup.  Like Alan said, it might be referring to the bearings, such as factory or the Green bearing replacements.
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
Re: which axles?
« Reply #5 on: July 23, 2014 - 10:21:58 AM »
For one it says to remove the center axle nut to pull out the axle. For the other it says to remove 5 bolts to pull out the axle. Different re-assembly instructions depending on what you have as well.
« Last Edit: July 23, 2014 - 10:24:41 AM by aris_unlimited »
Cuda is gone :(
Re: which axles?
« Reply #6 on: July 23, 2014 - 05:36:11 PM »
Up until 63 the 8 3/4 had 2 piece axles , there was a nut on the end & the flange was removable / keyed , pian in the a$$ to work on , 64 up used 1 piece axles
Re: which axles?
« Reply #7 on: July 24, 2014 - 02:39:47 AM »
Good to know I have the better one then lol.
Also thanks for the bit of knowledge/trivia!
Cuda is gone :(
