Author Topic: Bottom radiator hose question  (Read 10025 times)
Offline Gus cuda
« on: July 23, 2014 - 11:06:51 AM »
Hello all, my car has been pushing coolant out the overflow. It doesnt matter how full it is, i tried replacing the cap with a 16 psi stant, didnt stop it. I noticed my bottom hose does not have the spring in it, do you think it is collapsing and causing this problem? If so, where could i find the hose with the spring? Temp guage never reads over half, but i know it could be wrong. I have checked all over it with a temp gun and at the water pump housing the highest temp i have seen is 185, engine is stock with a 26 inch radiator that is clean. I also have a 160 thermostat in it. Any help is appreciated, tired of leaving my mark everywhere i go. Thx Gus
Offline burdar
Re: Bottom radiator hose question
« Reply #1 on: July 23, 2014 - 11:10:59 AM »
How full are you filling it?  I have mine about an inch down.  I still get a little dribble once in awhile.  If I wasn't concerned about looking stock, I would install an overflow tank.
Offline cudabob496
« Reply #2 on: July 23, 2014 - 01:19:25 PM »
may be over-filling
try a level 2 or 3 inches below top of radiator,
while keeping an eye on temps.
2011 Kawasaki Z1000
Offline Racer57
« Reply #3 on: July 23, 2014 - 03:20:05 PM »
I suspect your overfilling. I have a 180 stat and my mechanical gauge shows 190. The temp gauge on the dash shows not quite 1/2 way. Every time I've filled mine, it always pukes some out until its just barely above the fins in the radiator.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #4 on: July 23, 2014 - 04:51:08 PM »
 :iagree:  Mine  :puke:  when I shut it off after I've driven it a while on a hot day.  I would be more worried if you are leaking coolant while driving.
Make sure your fan is up inside your shroud too, this really helps keep things cooler.
« Reply #5 on: July 23, 2014 - 05:30:36 PM »
1st - there is a plate under the rad cap inside the tank , that is the max fill line .
2nd - are you getting constant bubbles with the cap off if so you could have compression entering the cooling system
Offline burdar
« Reply #6 on: July 23, 2014 - 07:00:36 PM »
That's what I though too but he said the temp has never gone up. I would think there would be overheating issues if there was compression in the cooling system.
Offline Gus cuda
« Reply #7 on: July 23, 2014 - 08:47:19 PM »
Ok folks ill try to address your suggestions. First it doesnt seem to matter where the coolant level is, i have let it drop down to the fins and its still pushing it out. When i say pushing it out, im talking a "running puddle". If it were a few drips i wouldnt worry. The car doesnt seem to be overheating, no steam, or burbling. Car runs fine, and there is no coolant getting into the oil or vice/versa. As far as bubbles while the cap is off, i will check that in the morning. Thx to all of you!
Offline cudabob496
« Reply #8 on: July 23, 2014 - 10:47:10 PM »
maybe fill neck on radiator is not level, or damaged, and not allowing
cap to seal properly.
« Last Edit: July 24, 2014 - 01:21:47 AM by cudabob496 »
2011 Kawasaki Z1000
Offline cjm
  • 70 Cuda - In Progress.....
« Reply #9 on: July 24, 2014 - 12:01:48 AM »
Are you 100% sure that it is coming from the overflow hose. There could be a leak in the radiator itself the causes the flow to "trail" off the overflow (side of the hose) without physically travelling through the overflow itself...
Offline Gus cuda
« Reply #10 on: July 24, 2014 - 07:40:25 AM »
Update: i checked for air bubbles with the cap off. Didnt see any, left it run until the coolant was at a nice flow. As for a radiator leak, i will check it next time i drive it. Im pretty sure it is coming out the tube though. Also the "running puddle" im speaking of; i mean it puddles on the ground and runs, not like its a constant "run" out of the overflow. So it sounds like nobody is worried about my hose not having the spring? I was thinkin maybe its collapsing and not allowing the coolant to settle back down correctly. But hey, im no expert, just learning my way around this thing!
Offline ammo
« Reply #11 on: July 24, 2014 - 07:50:24 AM »
If you not sure if its the overflow hose or the radiator , I would just try lengthening the overflow hose away from the radiator a foot or two and see if you leak moves.    :2cents:
1973 dodge challenger
Offline cudabob496
« Reply #12 on: July 24, 2014 - 08:26:02 PM »
I have a quart size overflow bottle, and I keep the level in the alum
radiator about 3 to 4 inches below cap.  In the summer, I have to empty
the overflow bottle, and poor the coolant back into the radiator, about
once every 3 or 4 weeks. I have a 16 PSI cap.  Maybe it "relieves itself"
every once in a while. Especially when I am getting on it, and its
above 90 outside. Coolant system coolant expansion is normal. I change my cap regularly too.
I stopped using the kind of rad cap that have the red relief lever on the top.
http://www.summitracing.com/parts/sum-g1472/overview/
« Last Edit: July 25, 2014 - 02:49:51 AM by cudabob496 »
2011 Kawasaki Z1000
Offline cudabob496
« Reply #13 on: July 24, 2014 - 09:12:57 PM »
Maybe your temp gauge is bad, and you are having an overheating condition.
So, maybe start thinking about all the things that could make a car overheat?
plugged radiator, timing off, stuck thermostat, fan 1/2 inch from Rad, and fan halfway in shroud, etc etc
too high a coolant concentration can hurt cooling.
« Last Edit: July 25, 2014 - 02:51:15 AM by cudabob496 »
2011 Kawasaki Z1000
Offline Gus cuda
« Reply #14 on: July 25, 2014 - 06:52:58 AM »
I'm pretty sure the rad is not clogged, upon inspection I see that my fan is about halfway into the stock shroud. Is that correct? If not what can I do to move it in closer? Haven't checked the timing, car seems to be running as it should. As for coolant, I keep it 50/50. As for a stuck stat, it is only 2 yrs old but I guess it could be bad already. Guess I have some trouble shooting to do, also maybe install an overflow bottle. I do appreciate all the help in what direction to go in from here. :cheers:,
