Author Topic: Radiator and gas tank  (Read 1045 times)
Offline chongo25
« on: July 23, 2014 - 04:48:24 PM »
Any suggestions on what to buy and where to buy. My gas tank it's pretty done and I  can't hot tank it, so I was told because of how bad the rust is on the inside. My radiator is also gone. This is for a72 slant 6 challenger.
Offline crash340
Re: Radiator and gas tank
« Reply #1 on: July 23, 2014 - 05:04:50 PM »
Spectra gas tank is the best if you want to retain original look, I got mine from Rock auto
Greg
73 Cuda
Brisbane, Australia
Offline jimynick
« Reply #2 on: July 23, 2014 - 05:08:23 PM »
I bought one for my 74 Challenger off Ebay for about $110+ shipping. I believe it was a Spectra brand. Many of the bigger suppliers have them if you attend a large show and you can save the freight. The rad, if original, can be re-cored or there's a selection of aftermarket rads available. Some are the aluminum fabricated ones and you can pick the size you want/need. Hope that helps.  :2cents:
Offline cudabob496
« Reply #3 on: July 23, 2014 - 05:18:22 PM »
If changing out radiator, I go with aluminum.
« Last Edit: July 23, 2014 - 07:59:51 PM by cudabob496 »
2011 Kawasaki Z1000
« Reply #4 on: July 23, 2014 - 05:32:20 PM »
Champion is a good option for alum rads
Offline chongo25
« Reply #5 on: July 23, 2014 - 07:30:27 PM »
http://www.ebay.com/itm/1971-1972-early-Dodge-Challenger-gas-fuel-tank-CR8F-new-steel-tank-4-side-vents-/330769895602
Why is this cheaper than the others? I talk to someone with summit and they ranged from 175 to 235, Im just curious if the price difference is worth paying. I don't mind paying more but I like to get make sure it is worth buying.
The radiator they had was 2 core aluminum and it was around 240, the tubes were bigger so i guess it would cool it better than a normal 2 core.
Offline dpcd67
« Reply #6 on: July 23, 2014 - 08:53:24 PM »
The less expensive gas tanks are made from galvanized steel and some of the more expensive ones are Ni Terne steel, which is lead coated.  I went with the galvanized steel one.  Some recommend to paint them where they contact the trunk pad; I didn't but probably is a good idea.
1963 Dodge M37 (3)
1967 Dodge WM300 (2)
1971 Plymouth Duster
Bought new in '71; I wanted the Challenger but they were $2850; too much $ so I got the 318, 3 speed on the floor, Twister Duster for $2100.
1973 Plymouth Barracuda
I ain't done yet.
Offline chongo25
« Reply #7 on: July 23, 2014 - 08:58:34 PM »
Is the lead coated on the inside?
« Last Edit: July 23, 2014 - 09:19:04 PM by chongo25 »
Offline dougs bs23
« Reply #8 on: July 24, 2014 - 10:07:06 AM »
Rock auto for the fuel tank, but reuse your original lock nut for the sending unit. it's a little thicker metal and will give you a better seal, and correct me if I'm wrong but I think Challenger Gary (member here) sells Champion rad's.  That's where I got mine and am completely happy with it.
Offline chongo25
« Reply #9 on: July 25, 2014 - 03:52:19 PM »
Thanks for the help
