Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
The Good Stuff
Member's Restoration Projects
(Moderators:
4Cruizn
Oldschool
'70 Challenger WSS (A91)
« previous
next »
Print
Pages:
1
2
3
Author
Topic: '70 Challenger WSS (A91) (Read 9828 times)
djwhog
Jr. Member
Re: '70 Challenger WSS (A91)
Reply #15 on:
August 12, 2014 - 09:23:17 PM »
welcome and nice rides, will look amazing when done too
congrats
Logged
don340-4
Jr. Member
Reply #16 on:
August 13, 2014 - 12:09:19 AM »
Great to see another WSS will be on the road again, keep up the good work.
Logged
Don
1970 Challenger R/T SE
1970 Challenger Western Sport Special
1969 Plymouth Road Runner
2012 Ram 1500 R/T
Topcat
C-C.com Expert
Member since 9/16/04
Reply #17 on:
August 13, 2014 - 02:11:49 AM »
I used Rust Bullet on the inner quarter panel frame area.
I've read stories where POR 15 was chipping off after time.
Looking good.
Logged
Rob C
Jr. Member
Reply #18 on:
August 13, 2014 - 01:17:44 PM »
This is exactly what I am saving up for now!
Subscribed!
Logged
'73 Cuda, 360, 4psd & 4.10's
'79 Dodge Magnum, 360, 727, 9-1/4 W/3.55's
383WSS
Jr. Member
Reply #19 on:
December 17, 2014 - 04:00:24 PM »
Been a while since I posted but I finally got the new roof skin on. It had some fitment issues but nothing major. I did use panel bonding adhesive to really make a water tight seal on that skin and coated the frame with POR15 before I did so. I left the metal bare on the parts that had the adhesive bead. A bunch of C clamps and the job is done. that roof is on there tight! Since then I have removed what you can see in the pic so I can tear away at the A pillars and upper cowl. More pics to come.
Logged
383WSS
Jr. Member
Reply #20 on:
December 17, 2014 - 04:10:20 PM »
Here you can see the rust holes in the upper cowl panel.
Logged
383WSS
Jr. Member
Reply #21 on:
December 17, 2014 - 04:13:19 PM »
Although the passenger side a pillar wasn't badly rusted it still has to go because I'm doing the upper cowl swap and the kick panels. This, however, is the driver side. Ouch!
Logged
383WSS
Jr. Member
Reply #22 on:
December 17, 2014 - 04:25:41 PM »
I decided to make a rough cut out of the upper cowl so I have more room to work through those spot welds.
Logged
383WSS
Jr. Member
Reply #23 on:
December 17, 2014 - 04:27:17 PM »
Latest pic. One of the grates was missing. as you can see it filled up with tons of leaves when it was stored outside about 10 years ago. Once I have a clean cutaway of the upper cowl I'll wire brush away the surface rust and probably do a POR15 coating as well before setting the new pillars and upper cowl panel.
Logged
383WSS
Jr. Member
Reply #24 on:
February 21, 2017 - 06:22:50 PM »
Hey Guys!
Just wanted to update my progress. My biggest problem is having multiple projects and also helping others with theirs. But no more! My Challenger has moved from the garage to my outdoor (covered) work area and I've begun really powering through getting this thing back together.
As you can see I have the upper cowl removed, I have the new roof skin attached and after taking the fenders and doors off I realized how bad the outer kick panels had rusted
Logged
383WSS
Jr. Member
Reply #25 on:
February 21, 2017 - 06:26:26 PM »
Here is the drivers side A-pillar removed. I decided not to completely dismantle the kick panels and instead fabricate only the sheet that attaches to the firewall because that's all that was required.
Logged
383WSS
Jr. Member
Reply #26 on:
February 21, 2017 - 06:28:33 PM »
aaand here is the new drivers side a-pillar installed and waiting for the panel bonding adhesive to dry. This stuff is absolutely great if you prep your work before you using. I feel confident that there will be no moisture seepage inbetween spot welds.
Logged
usraptr
Sr. Member
Reply #27 on:
March 12, 2017 - 07:13:52 PM »
Impressive work!
Logged
1970 Plymouth 'Cuda. Matching numbers 440 U Code, 4 speed pistol grip, Rallye dash, AM 8 Track, Shaker hood, 15 inch rallye wheels, Dana 60 4.10, Super Track Pak. One of 134 - 440 "U" coupes codes built in 1970 and one of 100 - 440 Super Track Paks built in 1970.
Restoration pictures at:
http://spanks4thememory.smugmug.com/Cars/70-Cuda/7240639_M24oi#465274575_2MBqW
(Edited 8-1-17)
"usraptr" = United States raptor - bird of prey = United States Bald Eagle. FYI, somebody else thought of it first so I had to drop the "O" in raptor.
jimynick
Resident
Reply #28 on:
March 12, 2017 - 11:35:16 PM »
Good work! I can see you're in the same boat as I was- the more you look, the more you find, rustwise. It's amazing how the years fly by, eh? Keep at her, you'll get there.
Logged
383WSS
Jr. Member
Reply #29 on:
March 20, 2017 - 03:18:39 PM »
Finally got the upper cowl from AMD. Fitting was a bit of a pain. A lot of manipulating and bending and hammering to get it to sit just right and I'm still 90% on the fitment.
Logged
Print
Pages:
1
2
3
« previous
next »
Cuda-Challenger.com
The Good Stuff
(Moderators:
4Cruizn
Oldschool
