Author Topic: Hood Hinge Threaded Plate Needed  (Read 1345 times)
Offline cwestra
« on: July 30, 2014 - 11:03:15 AM »
Does anyone have an extra hood hinge plate (see picture) or know where I could pick one up at?  This is the part that sits inside the inner fender for the front hood hinge bolt.
Corey - in Northern Indiana
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Hood Hinge Threaded Plate Needed
« Reply #1 on: July 30, 2014 - 01:39:54 PM »
Have you tried Dave at Roseville?  Or moparts?
Offline cwestra
« Reply #2 on: July 30, 2014 - 02:39:49 PM »
Any idea what the part is called?
Offline anlauto
« Reply #3 on: July 30, 2014 - 06:36:48 PM »
There's no reproduction of that... :2cents:
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #4 on: July 30, 2014 - 07:31:53 PM »
Looks fairly easy to make. Is the part missing or is the bolt hole stripped out or something. ?
« Reply #5 on: July 30, 2014 - 08:01:36 PM »
Must be someone here with a scrapped body that it could be pulled from , B body 71 up should have the same plate
« Reply #6 on: July 30, 2014 - 09:41:46 PM »
 :iagree:  I had the same thoughts...?
Offline vinb
« Reply #7 on: August 01, 2014 - 08:52:05 PM »
If you have access to it drill and tap it up one size, better then cut and welding..
Or try a Heli-Coil...
« Reply #8 on: August 01, 2014 - 11:13:03 PM »
Brad, you would think that about making a cylinder head!
We're not all tool and die guys, ya know.... :bigsmile:
with milling machines.......
lathes......
 :bigsmile:
« Reply #9 on: August 02, 2014 - 07:53:02 AM »
lathes......
 :bigsmile:
 :)  I hear what your saying but you could make that with a disc grinder and a electric drill.
If the threads are stripped what about welding a nut on the backside. Then run a tap through after welding.?
cwestra if you get me a paper/cardboard template of what you need I'll make you one?
I did something very similar with the bottom door hinge on my 55 Belair.
« Reply #10 on: August 02, 2014 - 10:41:11 AM »
lathes......
 :bigsmile:
  We're not ?  I'm just learning myself   :bigsmile:
« Last Edit: August 02, 2014 - 10:44:08 AM by johns cuda shop »
Offline cwestra
« Reply #11 on: August 02, 2014 - 04:10:18 PM »
Thanks for the offer, Brad.  I'm going to see if I can find one at the Nationals next week.  If not, I may take you up on it.  Mine is lost, not damaged.  I had my hood and hinges off the car a few weeks ago and took the car up to the parts house to get a couple of things.  It must have fallen out then.  Right now I just have a nut and washer in there.
