Author Topic: fuel line  (Read 1283 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
fuel line
« on: July 30, 2014 - 08:39:58 PM »
Hello all
I have a 1974 challenger with a 360. For some reason I ordered 3/8 fuel line from the tank to the fuel pump. My sending unit is 5/16. I have the pre bent fuel line from the pump to the carb that is 5/16. Is it an issue having  2 different sizes? will that cause a fuel pressure issue or should I just get the 3/8 line from the pump to the carb?
Offline Strawdawg
    • Vortex Buicks
Re: fuel line
« Reply #1 on: July 30, 2014 - 08:49:02 PM »
Should be fine
Offline elmoska
Re: fuel line
« Reply #2 on: July 30, 2014 - 09:18:18 PM »
i also have a 74 challenger with a 360. where did you get your fuel line exactly
1974 challenger on its way..
Re: fuel line
« Reply #3 on: July 30, 2014 - 10:34:32 PM »
Should be fine
The only issue you may have is the piece of rubber fuel line from the sender to the 3/8" line. You will need to use 3/8" rubber fuel line and clamp it tight enough to seal on the 5/16" sender. :2cents:
Offline anlauto
Re: fuel line
« Reply #4 on: July 30, 2014 - 10:49:32 PM »
You're fine....Most cars have 5/16 Pump to carb lines.
Offline 74 challenge
Re: fuel line
« Reply #5 on: July 31, 2014 - 08:22:07 AM »
I actually made this mistake when ordering my Tank sending unit, the line is 5/16 but the sending unit was 3/8 like the others said i just clamped it down and it hasn't leaked a drop in the past 2 years. You should be fine.
I'm running a 74 challenger with a 318.
1-8-4-3-6-5-7-2
Re: fuel line
« Reply #6 on: July 31, 2014 - 09:20:11 AM »
I think I bought it off ebay, but can't remember. It was about 6 years ago. Not sure how I ended up with 3/8 line.
Re: fuel line
« Reply #7 on: July 31, 2014 - 12:18:37 PM »
Fine Lines and Inline Tube sell line kits.  I think The Right Stuff does also.  I prefer Fine Lines.
