Author Topic: tie rod adjustment running out of adjustment for alignment  (Read 11658 times)
Offline dutch
Re: tie rod adjustment running out of adjustment for alignment
« Reply #45 on: August 22, 2014 - 07:16:55 AM »
did FF ever reply?
*** Bart ***
Offline crash340
« Reply #46 on: August 22, 2014 - 06:16:25 PM »
Dutch, yes they did. nothing positive. I have had a good friend suggest I at least run a shim under the steering box to rotate it a little to start with that way the new input shaft master spline will only be one or two splines away from the orignal rather than six or seven for example.
Greg
Greg
73 Cuda
Brisbane, Australia
Offline crash340
« Reply #47 on: August 23, 2014 - 05:36:38 AM »
Ok, final update,
I shimmed the left hand steering box bolt with about a 0.100" washer that I ground to have a taper on it so as not to stress the box mount lug too much. then re cut a new master spline on the Input shaft which now has three splines seperating the old from the new master spline. The tie rod ends are equal now.
Greg
Greg
73 Cuda
Brisbane, Australia
« Reply #48 on: August 23, 2014 - 07:32:51 AM »
We had some steering linkage issues and shimmed the steering box. Believe this picture came from factory or dealer info.
I posted that picture. ( I recognize the oil stains! LOL) It's from a Mopar performance chassis book.
Glad you got it sorted out!  :2thumbs:  You should have had to go though all that though.  :pullinghair:
Offline CUDA JAS
  • vroooooom!
« Reply #49 on: August 23, 2014 - 08:13:00 AM »
Ok, final update,
Greg
Glad you got t sorted out.
I think I am just going to go back to the factory pitman arm.  Not sure I like the idea of cutting a new master spline on the box.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline crash340
« Reply #50 on: August 23, 2014 - 06:24:26 PM »
Thanks guys,
Jas, it's pissed me off a little that they can seem to clock them right as such, I would have much prefered to not re cut etc, I guess bottom line is, I can always go back to original by taking out the shim and selecting the old master spline should I not like it or I actually find a correctly clocked arm one day, maybe try it, no harm.
Greg
Greg
73 Cuda
Brisbane, Australia
