Author Topic: ENGINE BLOCK DOWELS  (Read 913 times)
Offline arcticmopar
  • Yukon Canada
ENGINE BLOCK DOWELS
« on: August 01, 2014 - 05:31:28 PM »
 So another stupid problem...one of the two dowels on the back of my new block is stuck in my 727 trany bellhousing. Both seem a little tight going together and sure enough one pulled out. My cave man answer is to just sand down both to make it a little easier going together but figured I'd ask you guys what you would do? The dowells also are longer than the original ones in my old 383, they stick out about an inch from the block.
RUNS WHITH SISSORS!  and  DIGITALY CHALLENGED!
Offline roadman5312
Re: ENGINE BLOCK DOWELS
« Reply #1 on: August 01, 2014 - 05:43:43 PM »
They are very important for proper alignment. Get new ones that are correct for the application, believe me it will save you tons of possible grief down the road.  :2cents:
Offline arcticmopar
  • Yukon Canada
« Reply #2 on: August 01, 2014 - 06:42:55 PM »
Ok second question...how would you install one...with using a hammer?
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #3 on: August 01, 2014 - 07:00:31 PM »
I always used 1/2 dowel pins. I stick um in a freezer for a day or two ( To shrink them a little) then drive em in.  :bigsmile:
Offline arcticmopar
  • Yukon Canada
« Reply #4 on: August 01, 2014 - 07:36:15 PM »
Now there's a good idea..thanks John.
« Reply #5 on: August 01, 2014 - 10:07:08 PM »
I have polished them down slighty with a fine file
Offline arcticmopar
  • Yukon Canada
« Reply #6 on: August 02, 2014 - 01:30:30 PM »
Thanks Chryco, thats what I was figuring to do this weekend. That and a little more gringing on the K-frame,this sucker gotta fit!
