Author Topic: Weird utility trailer light problem (I know, not a mopar)  (Read 608 times)
Offline DocMel
« on: August 01, 2014 - 06:35:15 PM »
Posting here because of good help history:
I have a simple and small utility trailer
All my trailer lights work fine  (four pin) : Brake, tail and running lights, all good to go
Now here is the prob:
Everything works ok, EXCEPT when the engine is running.  I know, it sounds crazy.
As long as the engine is NOT running, all the lights work ok
When the engine is running, the turn signals become very weak and work very erratically
Re: Weird utility trailer light problem (I know, not a mopar)
« Reply #1 on: August 01, 2014 - 10:24:53 PM »
do you have a good ground on both , it may be using other circuits to ground & cannot ground when running ?
Offline pink panther
« Reply #2 on: August 02, 2014 - 11:34:46 AM »
maybe the flasher
Offline DocMel
« Reply #3 on: August 02, 2014 - 03:47:02 PM »
Grounds were the first thing I checked.  I have three grounds.  At the hitch, and at each taillight.   But what i did just in case was to retap each ground into the frame, just in case
Flasher is relativley new, but Ill switch out with a new one and see
Offline roadman5312
« Reply #4 on: August 02, 2014 - 04:22:34 PM »
 :popcorn: I have some ideas. Check voltage at fuse with key off, then key on.  I'm thinking maybe ignition switch. It has to have something to do with voltage in run mode vs off mode.   :clueless: I love this kind of stuff.   :scared:
« Reply #5 on: August 02, 2014 - 04:31:31 PM »
You may need an HD flasher with the extra load
