Author Topic: Power Steering hose - does this look right  (Read 1656 times)
Offline CUDA JAS
  • vroooooom!
« on: August 02, 2014 - 11:39:53 AM »
Just picked this up but it does not look right.
74 'cuda 360/727
Just call me a gearhead!
Offline roadman5312
Re: Power Steering hose - does this look right
« Reply #1 on: August 02, 2014 - 11:44:07 AM »
I just looked at the 70 challenger, the metal section is bent down, following the angle of the steering box, yours looks like its pointing up.
Offline anlauto
« Reply #2 on: August 02, 2014 - 11:47:32 AM »
As long as it has the correct "ends" and you can get it bolted in place with no kinks...you'll be fine :2cents:
« Reply #3 on: August 02, 2014 - 11:51:30 AM »
 :iagree:  my OE '73 just doesn't have so much bend in the bottom, you should be able to straighten a little so the hose lays flatter
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: August 02, 2014 - 12:16:18 PM »
Bend her flat so she gets away from the exhaust
« Reply #5 on: August 03, 2014 - 08:26:37 AM »
Mine lays flatter along the steering box. It was probably like that to fit in a shipping box?
Offline CUDA JAS
  • vroooooom!
« Reply #6 on: August 06, 2014 - 08:58:25 AM »
This was packaged in a baggie.
Here it is installed:
I am not sure I like it at this point.
Once installed on the pump side, it was very tight to attached the gear side.  Its almost like the hose is just a smidge to short.
I am not convinced there is enough slack in the hose to account for engine movement.
I think I am going to call and see if I can return it (it was special order)
Jason
74 'cuda 360/727
« Reply #7 on: August 06, 2014 - 09:46:18 AM »
The pump end is shaped very different than the OE.. Mine the metal tube turns straight up first then bends back down before curving toward the back...not saying what you have wont work
« Reply #8 on: August 06, 2014 - 09:59:55 AM »
checked rockauto.com .. this GATES Part # 356360 looks correct although the part pictured is rotated 180 from thew way it installs.
Offline CUDA JAS
  • vroooooom!
« Reply #9 on: August 06, 2014 - 10:32:39 AM »
Yes, but the fitting on the box end is different.
Jason
74 'cuda 360/727
Offline anlauto
« Reply #10 on: August 06, 2014 - 11:54:49 AM »
Jason...Just carefully bend the metal tube back a bit to give you more slack on the rubber hose :2cents:
Offline CUDA JAS
  • vroooooom!
« Reply #11 on: August 10, 2014 - 12:02:05 AM »
yeah...thanks Alan.  I nutted up and broke out the tubing bender...not it fits a lot better.
Suck when you have to make a brand new part fit...oh well.
Jason
74 'cuda 360/727
