Author Topic: What sequence for seam sealer, POR, & body plugs?  (Read 552 times)
Offline dakota
« on: August 02, 2014 - 11:56:52 AM »
Now that I've got the mouse hotel out of my backseat, I'm getting the rest of the crud out of the interior.   That includes the seam sealer which is past the end of its useful life.  I'm planning to apply POR to the floor pan.  Should I do the POR first, then the seam sealer or the other way around?   Also, I have a replacement set of body plugs.     I would think these should go on after the POR dries, but I wasn't sure if the POR will create a fitment issue with the plugs.
Offline dpcd67
Re: What sequence for seam sealer, POR, & body plugs?
« Reply #1 on: August 02, 2014 - 12:03:38 PM »
POR first, then paint if you are going to; if not, plugs, then put the seam sealer on, which won't interfere with the plugs anyway. It is intuitive once you think through the sequence. I just did this last week.  POR won't affect plug fit.  My seam sealer was falling off so I replaced it with 30 year black house calk.
« Last Edit: August 02, 2014 - 12:05:18 PM by dpcd67 »
1963 Dodge M37 (3)
1967 Dodge WM300 (2)
1971 Plymouth Duster
Bought new in '71; I wanted the Challenger but they were $2850; too much $ so I got the 318, 3 speed on the floor, Twister Duster for $2100.
1973 Plymouth Barracuda
I ain't done yet.
