Author Topic: clutch pedal  (Read 1043 times)
Offline sixbarrel
clutch pedal
« on: August 03, 2014 - 01:03:15 AM »
I have a 70 cuda 340 4 speed the problem I'm having is the pedal doesn't return all the way it stops short about 1 or 2 inches I can bump it with my foot and it pops out the clutch works fine has anyone heard of this and if so do you know of a fix?
Thanks
Re: clutch pedal
« Reply #1 on: August 03, 2014 - 01:02:14 PM »
I replied in the other post but it is better here , anyway adjust the length of the pushrod longer so the pedal is pushed back higher so it will overcenter pulling the pedal all the way to the top
Offline cwestra
Re: clutch pedal
« Reply #2 on: August 03, 2014 - 01:11:14 PM »
I had the same problem on mine.  I ended up doing what CP said and it worked fine.  Doesn't take a lot of adjustment to make a difference.
Corey - in Northern Indiana
Offline sixbarrel
Re: clutch pedal
« Reply #3 on: August 03, 2014 - 05:50:10 PM »
New to the 4 speed I'm assuming that adjustment is at the transmission end of the rod?
Re: clutch pedal
« Reply #4 on: August 03, 2014 - 07:05:16 PM »
Yup at the end of the adjuster rod where it goes through the release fork
Offline sixbarrel
Re: clutch pedal
« Reply #5 on: August 03, 2014 - 09:10:31 PM »
Thanks you for all the info I really appreciate it.
Re: clutch pedal
« Reply #6 on: August 03, 2014 - 10:00:08 PM »
 :2thumbs:
 Welcome BTW  :wave:
