Author Topic: kick down linkage mods?  (Read 886 times)
Offline stinger
« on: August 04, 2014 - 08:15:44 PM »
after changing intake,carb,throttle bracket my 3 piece linkage is a bit to short by roughly a half inch. I can shortn the slot[easiest] or lengthen the top rod. anyone do either with ill effect?
Re: kick down linkage mods?
« Reply #1 on: August 04, 2014 - 09:54:24 PM »
Someone makes a short extension for the upper rod. I'm not sure who that is though. I made my own.
Offline stinger
« Reply #2 on: August 04, 2014 - 10:17:07 PM »
how?
« Reply #3 on: August 05, 2014 - 09:01:50 AM »
Drill a hole through a small piece of aluminum and cut threads into it.  Screw a stud into one end.(just threads in the other end)  Then you can install it between the front and back sections of the upper rod.  Obviously this only works if you have a two piece upper rod.
Offline stinger
« Reply #4 on: August 05, 2014 - 06:27:55 PM »
I ended up cutting and welding 1" of rod and lengthened the upper rod.now I can adjust the upper and middle rod in the center of the threads instead of the ends and have full adjustment.I only hope I didn't do damage to my trans,seemed fine. teat drive tomorrow
Offline stinger
« Reply #5 on: August 06, 2014 - 09:29:50 PM »
went for a test drive,all good firm shafts and part throttle kick down in a twisty road at 50 was awesome,car never drove better.but still I want more. time for a tf2 :dunno:
