Author Topic: hood pin without cable?  (Read 1669 times)
Offline dave73chally
« on: August 05, 2014 - 08:46:27 AM »
Looking to pull the trigger on a AMD RT hood real soon. I'm tossed between one with the hood pin cutouts or without. I like the hood pins for purely the cosmetic appeal as I intend to keep my stock latching system intact. Can you run the hood pins without the cable; just the clip through the pin locking it into place? I don't like the idea of the cable rubbing against the paint, I've seen some cars with wear in this area.
« Last Edit: August 05, 2014 - 08:48:35 AM by dave73chally »
73 Challenger
Offline polarbear123
Re: hood pin without cable?
« Reply #1 on: August 05, 2014 - 09:51:22 AM »
Thats what I do.
« Reply #2 on: August 05, 2014 - 09:53:51 AM »
No problem , you just need to make sure you put the clips in the same place so you do not lose tham , I often set them on the pins [not through] when the hood is open
« Reply #3 on: August 05, 2014 - 10:02:27 AM »
Awesome thanks  :thumbsup:
73 Challenger
Offline CudamanTom
« Reply #4 on: August 05, 2014 - 10:10:04 AM »
I thought the cables came with clear plastic insulation so it wouldn't scratch the paint.
If not, you could purchase the coated cable and make your own.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline bc3j
« Reply #5 on: August 05, 2014 - 10:53:10 AM »
My cables tend to rise slightly off the leading edge of the hood as the air flows around them when moving. So far I have no marks on the hood trim or headlight bezel.
« Last Edit: August 05, 2014 - 10:55:28 AM by bc3j »
Offline 67vertman
  • Member since 9-23-2005
« Reply #6 on: August 05, 2014 - 11:41:24 AM »
 :iagree:  Three years no issues.
« Reply #7 on: August 05, 2014 - 11:48:12 AM »
Thanks for the replies guys. I like that I'd have the option to run with or without the cables  :thumbsup:
I'm going for the hood pins, I love the look
73 Challenger
Offline Killer_Mopar
« Reply #8 on: August 05, 2014 - 12:09:33 PM »
I run mine without the cables, just put them in my back pocket at car shows and like others have said, leave them around the pins when working in the garage....
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #9 on: August 05, 2014 - 01:36:35 PM »
I like the look with the cables, and yes they are coated so it does not scratch the paint.
Offline FY1Cuda
« Reply #10 on: August 05, 2014 - 04:45:36 PM »
Our's were originally flopping around on the hood and causing a scuff.  Now we tuck the cable in the hood crack, and the loop under the hood snugs into the forward lip of the hood.
« Reply #11 on: August 06, 2014 - 12:37:56 AM »
 I have done it that way also
« Reply #12 on: August 06, 2014 - 07:23:24 AM »
After all of these awesome replies reassuring me, I got a smoking deal on a brand new AMD hood without the pin holes that I couldn't pass up  :rofl: :-X
$600 with brand new AMD inserts, shipped to my door with no freight charge!
73 Challenger
Offline dfrazz
« Reply #13 on: August 06, 2014 - 09:27:13 AM »
Congrats!!  :woo:
