Author Topic: Identify my 440cui  (Read 2718 times)
Offline andben
Identify my 440cui
« on: August 05, 2014 - 02:41:07 PM »
Hi, I got a bigblock engine in my Challenger (clone 440) and it says "6 T440 E H P -  7 14 2"
Can you guys "decode of experties" translate to human language?  :bigsmile:
e-body for life
Offline HP_Cuda
  • Mopar or No Car!
Re: Identify my 440cui
« Reply #1 on: August 05, 2014 - 02:58:50 PM »
HP block first shift
1969 block most likely meant for 1970 model year but possible 69 year
Hopefully you still have the steel crank and six pack rods.
B
« Reply #2 on: August 05, 2014 - 06:56:43 PM »
I will go the other way , I believe this is a 6T is a 76 block / engine 440 E cast crank HP
if the E was in front of the 440 I would say 69 but after is cast crank
http://www.moparts.org/Tech/Archive/motor/36.html
Offline 1 Wild R/T
« Reply #3 on: August 05, 2014 - 08:04:14 PM »
Yup, 76 Cast Crank HP most likely from a cop car... 7.8-1 C/R..
Offline anlauto
« Reply #4 on: August 05, 2014 - 10:16:25 PM »
The VIN on the passenger side of the block will confirm what year the vehicle was that it came out of... :2cents:
« Reply #5 on: August 05, 2014 - 10:26:10 PM »
The casting numbers are another way to determine year.
http://board.moparts.org/ubbthreads/showflat.php?Number=5773925
Offline MTS-Challenger
  • Vanishing Point - "Catch Me If You Can"
« Reply #6 on: August 06, 2014 - 04:28:01 AM »
This is what I found
6T = 1976
440 = CID
E = Cast Crank
HP = High Performance (never heard of 1976 HP block with cast crank - so maybe cop car?)
7142 = 10,000 day Julian Calendar (you'll need to check your numbers again 7142 = 2/15/81)
References:
http://www.440source.com/blocks.htm
http://www.440source.com/blockinfo.htm
http://maxwedge.com/articles/10k.php
 :wavingflag:
1970 Challenger R/T 440
Offline andben
« Reply #7 on: August 06, 2014 - 08:14:30 AM »
6T = 1976
440 = CID
E = Cast Crank
References:
 :wavingflag:
Look again, it's E H P (not E HP) so it's probably seperated H and P. That makes it "standard 4bbl" and "fuel recommended" ?!
e-body for life
« Reply #8 on: August 06, 2014 - 11:53:14 AM »
E H P
hhmmm, looks like we need more information from the block - cast numbers, VIN pad numbers and harmonic damper ID.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #9 on: August 06, 2014 - 06:15:18 PM »
I'd like to see a pic of the raised portion of the block.
That way there is no guessing
