Author Topic: Gas tank parts list?  (Read 2035 times)
Offline shoooter
« on: August 09, 2014 - 02:06:50 AM »
Does anyone have a parts list and numbers for a gas tank install on a 71 cuda with a er8e tank? What filler neck is used? Is there a grommet at both ends? I see some people use a gas tank pad that goes between the tank and floor? gas tank strap pads as well? What sending unit?. I want to order everything at once.. Also who sells premade fuel lines or do you make your own? thanks again everyone
Offline anlauto
Re: Gas tank parts list?
« Reply #1 on: August 09, 2014 - 07:19:58 AM »
> Gas Tank w/four tubes on passenger side
> Gas Tank Vent Tube - Mounts in trunk
> Gas Tank Filler Neck
> Fuel Sending Unit - size depends on engine 318-383 use 5/16, 440+6-Hemi use 5/8 with 1/4 return
> Fuel Line Ground Strap
> Fuel Lines -Best are made by Fine Lines Inc
> Fuel Tank Pad - Performance Car Graphics
> Gas Tank Straps
> Gas Tank J bolts
> Fuel Neck-Tank Seal
> Fuel Neck to Floor Seal
> Fuel Neck- Body Foam Seal
> Gas Cap
« Reply #2 on: August 09, 2014 - 09:04:05 AM »
Talk to Dave @ Roseville
 I have not seen repro filler necks or vent tubes
Offline anlauto
« Reply #3 on: August 09, 2014 - 09:44:41 AM »
Filler necks YES, vent tubes NO
Offline CudamanTom
« Reply #4 on: August 09, 2014 - 10:45:55 AM »
You might find a used vent tube on ebay or somewhere (not very often though) but make sure none of the lines are clogged. They are a bear to clean and get uclogged depending how bad it is.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #5 on: August 09, 2014 - 10:49:18 AM »
I have a original vent tube off my '71 Chally.  Not sure if it is the same as the Cuda.
Offline CudamanTom
« Reply #6 on: August 09, 2014 - 10:54:31 AM »
Nope, totally different.
Offline anlauto
« Reply #7 on: August 09, 2014 - 11:57:54 AM »
Yes EXACTLY the same. :2cents:
Offline CudamanTom
« Reply #8 on: August 09, 2014 - 01:15:52 PM »
Oops, I got that wrong. Sorry.  :banghead:
I was thinking filler neck. My bad.
« Last Edit: August 09, 2014 - 04:18:24 PM by CudamanTom »
Offline dfrazz
« Reply #9 on: August 10, 2014 - 01:37:24 AM »
Shooter - send me a PM if you are interested in my vent tube.
« Last Edit: August 10, 2014 - 01:40:41 AM by dfrazz »
Offline 6771plymouth
  • john
« Reply #10 on: August 22, 2014 - 03:35:36 PM »
I bought a vent tube at carslile  do I really need?
Offline dfrazz
« Reply #11 on: August 22, 2014 - 03:42:35 PM »
I pulled mine when I installed my new trunk floor and am just running a correctly vented cap.  I tied off the 4 valves at the bottom of the tank.  No issues.
