I'll take that back... Driving the car today, it was charging like crazy, way more than normal, supercharger... Then suddenly it stopped, then it started charging again, but this time only a little bit, needle moves a little bit when I rev the engine but not that much, if I have the lights on its more on the D side. Very stange. Can't measure the voltage on the battery now since its pouring rain here. I need to check the connections again, did that before I changed the regulator, with no results, and I also checked that the regulator had good ground in the firewall. Could be a battery problem also.
