Author Topic: QA1 front set-up  (Read 1781 times)
Offline ff6849
QA1 front set-up
« on: August 11, 2014 - 06:14:44 PM »
Has anyone installed a complete QA1 front suspension yet with their upper and lower control arms, strut rods, and tubular k member. I did a couple of searches unable to find any feed back. Curious to see how they worked out, considering this myself.
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
Re: QA1 front set-up
« Reply #1 on: August 11, 2014 - 07:25:00 PM »
I think QA1 bought the suspension design from the CAP auto products before they went out of business. I am sure they improved on the quality but I personally don't know anyone who has used it. I believe there is a thread over on moparts.com about it.  :bigsmile:
Offline Travis72
« Reply #3 on: August 12, 2014 - 01:20:28 AM »
Joe, seriously??? You have Dan the Man in town and you're not going with Hotchkis parts?   ;D  Actually using the QA1 tubular k-member with all the other Hotchkis parts might be a really trick setup (provided the QA1 quality is there).  I know Dan was interested in checking out the QA1 k-member in person.
Travis
72 Cuda
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #4 on: August 12, 2014 - 08:38:44 AM »
Travis
72 Cuda
If all things went according to plan, I wanted to do the QA1 tubular K-frame and lower control arms, then everything else hotchkis
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline ff6849
« Reply #5 on: August 12, 2014 - 02:05:29 PM »
Travis
72 Cuda
That was the  plan actually Travis, Hotchkis upper control arms with QA1 lowers control arms and k-member.
« Last Edit: August 12, 2014 - 02:13:48 PM by ff6849 »
73 440 Cuda'
4.10 rear gear
comp XE274H cam
Holley Sniper EFI
MSD ignition
Offline waskier
« Reply #6 on: July 06, 2016 - 01:38:48 AM »
Did you get anywhere with this?
Offline ff6849
« Reply #7 on: July 06, 2016 - 10:04:34 AM »
I have not
73 440 Cuda'
4.10 rear gear
comp XE274H cam
Holley Sniper EFI
MSD ignition
