Author Topic: Wiring cleanup suggestions  (Read 3096 times)
Offline RCCDrew
« on: August 12, 2014 - 10:27:57 PM »
How do you guys keep your wiring clean and organized looking? Or how do you keep it out of sight?  I've added several electrical accessories and upgrades and need some suggestions.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: Wiring cleanup suggestions
« Reply #1 on: August 13, 2014 - 05:39:14 AM »
I re-ran all my wiring through a black loom with electrical tape as needed.  My battery, MSD, and brake vacuum pump are in the trunk with a loom running against my inner fender, under my rocker, and into the engine bay through the mud flap on the driver side front inner fender.  I moved the starter relay down under the master cylinder and all wiring runs behind the engine to hide it.
Offline RCCDrew
« Reply #2 on: August 13, 2014 - 06:56:36 AM »
Nice! Do you still have the alternator wiring running over the intake manifold?
Offline dfrazz
« Reply #3 on: August 13, 2014 - 10:05:37 AM »
Yes, and its a 1-wire alt.
« Reply #4 on: August 13, 2014 - 10:08:13 AM »
 :popcorn:  I'm planning a wiring upgrade soon , so looking for idea's too!  :wave:
« Reply #5 on: August 13, 2014 - 10:23:03 AM »
« Reply #6 on: August 13, 2014 - 10:34:50 AM »
It looks a lot nicer then the plastic wire loom.
I didn't search, does it come in bigger sizes? You would probably need some in the 3/4" & 1" size.
« Reply #7 on: August 13, 2014 - 10:51:32 AM »
Yes, it comes in other diameters.  It also expands quite a bit.  It's like a Chinese finger trap.
Offline dfrazz
« Reply #8 on: August 13, 2014 - 12:36:34 PM »
PM me if you want to chat more and I can give you all the details on what I did and learned along the way.  Happy to help!
« Reply #9 on: August 13, 2014 - 02:09:38 PM »
 :2thumbs:
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #10 on: August 13, 2014 - 03:05:54 PM »
I try to hide as much wiring I can .,I,m a fan of convoluted plastic split tubing.Its been around a while and the OEM and aftermarket use it alot. Has the advantage of adding wiring easily without fishing it all the way through the covering ,If you have to add something later ect. ect. I finish the ends with heat shrink . Looks nice  :bigsmile:
« Reply #11 on: August 13, 2014 - 03:10:27 PM »
I believe the covering I posted the link to is available in a split design.  It does make installation a lot easier.
« Reply #12 on: August 13, 2014 - 05:56:12 PM »
I'm probably going to use some of this stuff.
http://www.amazon.com/Techflex-PTN0-25BK25-General-Purpose-Braided/dp/B004UHJCFI/ref=pd_ys_sf_s_172282_b2_6_p?ie=UTF8&refRID=0F2W9WZ2V9VFWM5MQ124
I've seen other people use it/suggest it on the net .  Just wondering?... how does it compare to regular convoluted plastic loom in regards to protection, impact/abrasion? With it being split how do you secure it ? Electrical tape? Zip ties?  :clueless:
Offline Racer57
« Reply #13 on: August 13, 2014 - 11:01:42 PM »
Is there interference issues with having the alternator wires and sparkplug wires all running in the same covered loom ? Assuming all wires are in good condition.
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #14 on: August 13, 2014 - 11:29:08 PM »
I used some 3/4 Inch Non Adhesive Dry Vinyl Wiring Harness Electrical Tape
Cheep, easy, effective...
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
