Author Topic: AAR 'Cuda Dealer Warranty Engine Replacement Question  (Read 7687 times)
Offline boudin
« on: August 13, 2014 - 01:13:02 PM »
Currently restoring an AAR, which is matching #s except for the motor. Story from the original owner is that the engine was replaced under warranty in 1970 due to a spun bearing. However, since I have no warranty paperwork, so I can't really confirm the story.
Motor that came with the car is a period correct 340, but NOT a TA block. If the motor was replaced under warranty, I would have thought that a TA motor would have been used? What do you think the likelihood? I know that bare TA blocks were available, but what about complete warranty motors? Any help would be appreciated.
Block that came with the car is:
PART # 2780930-340-8
SERIAL: FW340P31150382
Thanks,
-Greg
'70 AAR 'Cuda (restoration-in-progress)
Offline anlauto
Re: AAR 'Cuda Dealer Warranty Engine Replacement Question
« Reply #1 on: August 13, 2014 - 01:42:37 PM »
I would think that at that time....they would have replaced it with whatever they had, which was most likely a regular 340. :2cents:
Offline boudin
« Reply #2 on: August 14, 2014 - 11:23:36 AM »
We are rebuilding the existing 340 and it will stay with the car, unless by some miracle I find the original block. At the very least I have a good story to tell about why the block is not matching #s. Everything else matches, though: dash, door tag, fender tag, trans, cowl and core support. Found the broadcast sheet under the rear seat too.
-Greg
Offline anlauto
« Reply #3 on: August 14, 2014 - 11:48:00 AM »
What options does the car have ? Anything "extra cool " :smokin:
Offline 74 challenge
« Reply #4 on: August 14, 2014 - 11:53:13 AM »
I hope it has your favorite option - Body line moulding lol.
1-8-4-3-6-5-7-2
Offline boudin
« Reply #5 on: August 14, 2014 - 06:47:03 PM »
Have some fun and decode it. I did this in Excel to send out for a remake of the fender tag. Had to figure out the missing parts of the tag from the broadcast sheet.
« Last Edit: August 14, 2014 - 06:51:49 PM by boudin »
Offline AARuFAST
  • AARuFAST
« Reply #6 on: August 14, 2014 - 08:31:29 PM »
Do the heads have the offset rocker arms or tapper.......?
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline RzeroB
  • In The Lou and looking for a new (old) ride
« Reply #7 on: August 14, 2014 - 09:32:17 PM »
My understanding is if there is a partial VIN stamped on the engine's VIN pad then it is NOT a warranty block. Warranty blocks supposedly came with a clean VIN pad. But then again I have also heard that partial VIN stampings on the VIN pad have been machined off to create the illusion of it being a warranty block. Also my understanding is that warranty short blocks came with a service tag attached to right hand side of the block near the forward freeze plug.
On the other hand, at least the blocks serial number indicates that it is date correct: The "F" indicates that it is a 1970 model year block and the "3115" indicates that it was built on February 6th 1970.
« Last Edit: August 14, 2014 - 10:42:26 PM by RzeroB »
Cheers!
Tom
St Louis, MO
Former owner of 16 classic Mopars. "It is better to have owned (Mopars) and lost then to have never owned at all" (apologies to Alfred Lord Tennyson)
Offline boudin
« Reply #8 on: August 14, 2014 - 10:07:41 PM »
No offset, and no adjustable rockers.
-Greg
Offline boudin
« Reply #9 on: August 14, 2014 - 10:09:48 PM »
My understanding is if there is a partial VIN stamped on the engine's VIN pad then it is NOT a warranty block. Warranty blocks supposedly came with a clean VIN pad. But then again I have also heard that partial VIN stampings on the VIN pad have been machined off to create the illusion of it being a warranty block. Also my understanding is that warranty short blocks came with a service tag attached to driver's side of the block near the forward freeze plug.
Question I have is were there really "warranty" blocks, or just over-the-counter race blocks w/o serial numbers? Would the dealer be expected to build an engine, or just drop-in a crated long block?
Good info about the service tag... what would that tag look like?
Also, what is this stamping? (see red arrow in photo)
-Greg
« Last Edit: August 14, 2014 - 10:18:40 PM by boudin »
Offline RzeroB
« Reply #10 on: August 14, 2014 - 10:55:00 PM »
-Greg
My understanding is that dealerships did not build engines from bare blocks - they used factory built short or long blocks - what determined which one they used I don't know.
The service tag was a five sided blue and whit tag about about the same size as the freeze plug and attached to the block with a single rivet.
The stamping in the above pic looks like a misaligned "maltese cross" stamp which would indicate that the the crankshaft was .001 undersized from the factory.
« Last Edit: August 14, 2014 - 10:57:25 PM by RzeroB »
Cheers!
Tom
St Louis, MO
Offline boudin
« Reply #11 on: August 15, 2014 - 06:32:14 AM »
Good info. Thanks, Tom.
Offline AARTA340
« Reply #12 on: August 16, 2014 - 02:40:41 AM »
I have seen the maltese cross on  the upper pad of big block motors and it designated the presence of undersize bearings used. Not sure if it is the same for small blocks. Possibly, it is the place they could stamp it. It will be interesting if anyone else has some info. My car was made the day before according to the SPD. I like your color!! Beats my FF4
-Greg
Offline boudin
« Reply #13 on: August 16, 2014 - 02:18:19 PM »
Got my replacement fender tags from A. G. Backeast. Fast service! Took less than a week.
Offline anlauto
« Reply #14 on: August 16, 2014 - 04:31:05 PM »
You never said the car was a bench seat column auto.....That's pretty rare and unique for an AAR  :2thumbs:
