Author Topic: oil, temp gauge  (Read 2905 times)
Offline haplo
  • no i am not
oil, temp gauge
« on: July 30, 2002 - 10:20:48 PM »
Just got rally dash in oil,  temp gauge, not working fuel gauge , works any ideals.
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
Re:oil, temp gauge
« Reply #1 on: July 30, 2002 - 11:14:53 PM »
NEED MORE INFO- DOES ANY WORK??
OR DOES SOME WORK?
Offline haplo
  • no i am not
Re:oil, temp gauge
« Reply #2 on: July 31, 2002 - 09:52:14 PM »
The alt gauge, fuel gauge work .oil, temp do not. have tried grounding oil, temp wires at sending units no luck.
Re:oil, temp gauge
« Reply #3 on: August 01, 2002 - 02:56:22 AM »
Check to see if you aare getting power to the gauge it should be a pulsing power from the regulater that plugs into the back of the dash , you need to follow the power back to where you actually get power & start checking at that point  ;)
Offline 71 DEPUTY
    • Cardomain
Re:oil, temp gauge
« Reply #4 on: August 01, 2002 - 03:25:54 PM »
ALSO CHECK THE WIRES FROM THE OIL AND TEMP SENDING UNITS TO THE FIREWALL CONNECTOR-CHECK TO SEE IF THEY ARE PLUGED IN ON THE BACK OF THE DASH.  CHECK WITH A OHM METER TO SEE IF THERE IS SOME RESISTANCE ON THE GAUGE ITSELF- IF NO READING- THEN GAUAGE IS PROBLEY BURNT OUT
GET BACK TO US!!!
JOHN MAC
