Author Topic: Alternator Big red wire direkt to Batterie ?  (Read 1274 times)
Offline Rikuma
« on: August 15, 2014 - 06:26:11 AM »
In my 70 Challenger is all original unter the Hood. He have the original Alternator with external Regulator.
The Big +14 Volt Cable go to the Instrument Panel and then to the Battarie.
The Ampermeter i have disconnect because the cable was hot near the Ampermeter.
I will not burn the Dash with that hot + 14 Volt Wire.
It is possible to Route the Big + 14Volt Cable direkt from the Altornator (with external Regulator) to the Batterie?
Or is a One wire Alternator needed for this Application?
Regards Andy
Re: Alternator Big red wire direkt to Batterie ?
« Reply #1 on: August 15, 2014 - 08:15:57 AM »
I ran a heavy wire from the alternator lug to the battery to bypass the amp gauge ( sort of) Works for me.
Offline Rikuma
« Reply #2 on: August 15, 2014 - 08:56:01 AM »
Hey Brad
Thankyou
To you have the  original Alternator with External Regulator or a One Wire?
« Reply #3 on: August 15, 2014 - 11:00:37 PM »
It will work with either 1 wire or 3 wire alt , just run a heavy 10ga or bigger wire from the alt output to the bat terminal on the start relay
Offline brasil
« Reply #4 on: August 18, 2014 - 02:18:40 PM »
sounds good... but how is the dash feeded with power ?
Greetings Juergen
« Reply #5 on: August 18, 2014 - 03:23:42 PM »
You are just adding a parallel circuit, not removing the original dash feed. Although I would recommend disconnecting your ammeter  and connecting the two ammeter wires together.
« Reply #6 on: August 18, 2014 - 10:50:22 PM »
 the dash feed is through the fusable link from the start relay , into the bulkhead connector to the start switch & ammeter
