Author Topic: Alternator amp size  (Read 2400 times)
Offline 71340RT
Alternator amp size
« on: August 16, 2014 - 10:59:40 AM »
After putting EFI on my 73 Challenger I have found that the volt gauge is always charging 14.4-14.6 volts and seem to never settle down any lower. Can I put a higher output alternator on or what is the highest output my stock wiring will handle? I have already had a voltage regulator go bad at the Nats and it stopped charging again yesterday. I'm not sure if the alternator has went bad but will check it out today.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline ShelbyDogg
Re: Alternator amp size
« Reply #1 on: August 16, 2014 - 11:46:48 AM »
This is the one we spoke about. 78 Amp dual pulley at AutoZone. PN DL7533 I have 3 of them.
Application is for a Dodge 91 D250 3/4 ton 2wd 5.9 Cummins
http://www.autozone.com/autozone/parts/Alternator/_/N-93xme?filterByKeyWord=dl7533&fromString=search&isSearchByPartNumber=true
« Reply #2 on: August 16, 2014 - 12:37:16 PM »
I would recommend a jumper from the alt output across to the bat terminal on the start relay if you go above 55 amps
Offline 72bluNblu
« Reply #3 on: August 16, 2014 - 02:16:37 PM »
I run 100 amp Tuff Stuff alternators on my Challenger and Duster. Haven't had any issues with either car even running through the stock bulkhead connector, although I'm about to do a voltmeter conversion on my Duster because it runs a dual electric fan set up.
Offline Strawdawg
    • Vortex Buicks
« Reply #4 on: August 16, 2014 - 03:42:29 PM »
If your alternator is able to supply that much voltage, then it has plenty of amperage.  If it was low on the amperage, the voltage would be lower.
I suspect that there is a voltage loss somewhere in the circuit and the regulator is working hard to make up for it so it is telling the alternator to work harder.
If the feed is still going thru the bulkhead connector, I suspect that may be where the problem lies
« Reply #5 on: August 16, 2014 - 10:10:08 PM »
 You need to use relays to jump power from the start relay to the fans without going through the firewall & ammeter
 14,5 v is normal BTW
« Last Edit: August 17, 2014 - 12:21:39 AM by Chryco Psycho »
« Reply #6 on: August 16, 2014 - 10:19:18 PM »
Offline Katfish
  • 70 Challenger
« Reply #7 on: August 16, 2014 - 10:31:52 PM »
Is this a direct bolt in for a 70 SB, any fitment or wiring mods needed on the alternator itself?  Pulleys match up for AC?
I've already done the ampmeter bypass and have the headlights on relays.
Offline 72bluNblu
« Reply #8 on: August 17, 2014 - 04:35:17 PM »
Oh I do. It has a battery relocation with a cut-out and a 250 amp continuous duty relay up front that runs the 70 amp relays for the fans.
