Author Topic: car overheating  (Read 514 times)
Offline stang13
car overheating
« on: August 16, 2014 - 11:14:53 PM »
 :swear: I finally got my 70 challenger back on the road . I have installed an rebuilt 440 6 pk that has a stroker kit in it so I am putting out a lot of heat. the engine was rebuilt by a professional engine builder . it
runs strong and idles at about 900 rpms. Today it was about 80 degrees and I was on my was to a cruise . I stopped at a few traffic lights that were red and as I sat I watched the temp gauge rise into the hot zone . when I pilled into the lot I noticed a good not of antifreeze coming out of my overflow canister . I have a brand new aluminum radiator installed in it . I say I lost a few cups of antifreeze
 I let it cool and went home a different way with fewer lights with no overheating . any suggestions what I can do to prevent this I. The future. ?
Offline taxspeaker
Re: car overheating
« Reply #1 on: August 16, 2014 - 11:49:09 PM »
I think I would start with a couple of obvious, easy and cheap solutions:
1. Make sure it really is overheating-a lot of the aftermarket sending unit replacements I have found read high
2. With a fresh rebuild I wouldn't be surprised if you had some air pockets in the engine and hoses-very common and often a simple fix that fixes itself after a few refills.
3. Are you running a factory fan? I have seen lots of problems when not re-isntalling the factory shroud, or replacing the factory fan with an aftermarket fiberglass one or both.
Well thats a start-hope you get it, I'm sure by Sunday there will be a lot of suggestions
3.
Matching Alpine White/ Black Vinyl Top
Matching console/black interior automatic
1970 AAR Cuda (numbers matching)
1970 Superbird (unrestored)
We drive em! Watch out on I-65 in the Midwest and honk!
Offline stang13
Re: car overheating
« Reply #2 on: August 17, 2014 - 12:02:23 AM »
I have about 100 miles on the car without no overheating issues. I reused the shroud but I n running a fiberglass blade
Re: car overheating
« Reply #3 on: August 17, 2014 - 12:07:03 AM »
Engines will run hotter for the first miles after a rebuild but as you say it stayed cool before , my first recommendation is a 18" Flex-A-Lite fan 6 blade & a clutch , this will pull a lot more air , the problem you are having is air flow when sitting still if it cools Ok when moving so making sure the shroud I sealed to the rad with a good fan should keep the temps down , I would recommend a 180* T stat not 195* as well
