Author Topic: what am i missing?  (Read 1144 times)
Offline 6771plymouth
  • john
what am i missing?
« on: August 17, 2014 - 12:27:54 PM »
71 cuda where the arm rest is there are two places for screws but door panel has nothing?
Offline roadman5312
Re: what am i missing?
« Reply #1 on: August 17, 2014 - 12:41:49 PM »
On the Challenger there is a metal cup (if you will) that fits down in the armrest. Screws go thru it into door
Offline CudamanTom
« Reply #2 on: August 17, 2014 - 02:24:22 PM »
Mark is correct and applies to the cuda as well. But there is also an armrest/pad bracket that mounts there also. I will take a pic and post it.
« Last Edit: August 17, 2014 - 02:31:51 PM by CudamanTom »
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline CudamanTom
« Reply #3 on: August 17, 2014 - 02:30:42 PM »
Here is a couple pics.
And just to add, there is plastic cups made as well.
Hope that helps.
Tom
  • john
« Reply #4 on: August 17, 2014 - 04:16:47 PM »
thanks guys I bet these are gona be fun to find/ so that's two pieces or one
« Last Edit: August 17, 2014 - 04:22:49 PM by 6771plymouth »
Offline CudamanTom
« Reply #5 on: August 17, 2014 - 04:40:32 PM »
Two pieces.
There are some on ebay as we speak.
Look for cuda arm rest cup or bracket.
  • john
« Reply #6 on: August 17, 2014 - 04:46:10 PM »
thnx tom
Offline CudamanTom
« Reply #7 on: August 17, 2014 - 04:58:10 PM »
Oh,
Beware. There is one on ebay that is claiming to be 70 thru 74 but it has four square corners. That is not correct. You want the ones that have two squared corners and two rounded corners.
Also, if you find two that are for one side, you can drill a hole  in the right location for the lock rod that protrudes the cup. I had to do this myself and looks pretty good. And it really can't be noticed unless it's a show/judged car maybe.
But there is a difference in the right side and left side. Just so you know.
  • john
« Reply #8 on: August 17, 2014 - 06:27:08 PM »
Dsmn might have just bought the wrongbones then dint see any cups
  • john
« Reply #9 on: August 17, 2014 - 06:52:37 PM »
Oh well i got brackets dint see any cups
Offline CudamanTom
