Author Topic: Installing eveery thing finding issues "help"  (Read 1184 times)
Offline cudasteve72
« on: August 17, 2014 - 01:38:32 PM »
So I am in the process of installing all the clutch components.  I believe I have them all in correctly, but the pedal dosent come back up.  you can feel it go down past where the over center spring pulls it up, an i think it feels like the throughout bearing is engageing the preasure plate, but the pedal just stays there.  It is a new mccloud plate new z bar, rod, bushings, adjuster etcetc.... Can the over center spring be in wrong? is there another spring besides the clutch for return and over center?  I am at a loss.
1972 Cuda Custom 70 clone  416 stroker 481/531 hp/
2006 Grand Cherokee SRT8 (daily)
1970 Challenger convertible 340 (Dad's)
1967 Dart gt slant six all original 40,000 miles driver but needs restoration (Brother's)
2011 Jeep Grand Cherokee (wife's)
Offline CudamanTom
Re: Installing eveery thing finding issues "help"
« Reply #1 on: August 17, 2014 - 02:20:21 PM »
Do you have the spring from the clutch fork to the bellhousing installed?
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline cudasteve72
« Reply #2 on: August 17, 2014 - 03:08:19 PM »
yup that one is on there.
Offline CudamanTom
« Reply #3 on: August 17, 2014 - 03:26:26 PM »
The pressure plate should be providing spring action too. So the spring and pressure plate should return the pedal.
Might be an adjustment either at the pedal linkage or clutch fork rod.
Can you provide a pic of the pedal and spring under the dash?
Also a pic of the spring down at the clutch fork?
« Reply #4 on: August 17, 2014 - 08:20:09 PM »
lengthen the adjuster rod so the pedal comes up higher & over centers
Offline crocha617
« Reply #5 on: August 18, 2014 - 09:23:58 PM »
If that clutch is a diaphragm style clutch you need to remove the over center spring.
Offline 1 Wild R/T
« Reply #6 on: August 18, 2014 - 09:37:45 PM »
