Author Topic: Hood trim fitment  (Read 1289 times)
Offline dave73chally
Hood trim fitment
« on: August 17, 2014 - 11:15:33 PM »
Have a 73 challenger, just installed an AMD RT hood. My 73 hood trim is about 1/2" short on both ends of the hood and overall fitment is poor. Do I need a trim piece from a different year?
73 Challenger
Re: Hood trim fitment
« Reply #1 on: August 18, 2014 - 12:40:58 AM »
Weird so the hood fits properly but suddenly the trim is 1" short ? the only way I could se that happening is if the hood has more Vee across the front edge
« Reply #2 on: August 18, 2014 - 07:28:52 AM »
Yea, I'll try to get a picture tonight. I'l also see if it'll bend and give a little bit in the V portion to spread slightly
73 Challenger
« Reply #3 on: August 18, 2014 - 03:37:27 PM »
The 72-74 trim attaches different then 70 and 71.  Philips head screws are used instead of clips and nuts.  Do you have the right trim?
« Reply #4 on: August 18, 2014 - 04:43:36 PM »
I have the 73 trim that attaches from the bottom with the screws. I was going to drill and attach the same way as my original hood, wasn't aware there was a difference.
Do you have a vendor/part # for the correct hood trim? I'll just go ahead and buy the new one since fitment isn't right either
73 Challenger
Offline dakota
« Reply #5 on: September 24, 2014 - 08:34:22 PM »
I have a 70 Challenger.   The hood trim measures 52" long total (26" each leg from the center point of the V).  The existing hood trim (may be original?  not sure) has a blacked-out flange that screws into the underside of the hood.   I just received a "70-71" replacement piece from Roseville that is the same length but doesn't have the flange on the bottom.   The replacement trim has a set of mounting screws that slide in to the backside of the trim and then through the front lip of the hood.   My hood has holes for both mounting approaches.
« Reply #6 on: September 24, 2014 - 09:33:51 PM »
My trim ended up fitting, it was just a bit bent and was able to shape it back fit
73 Challenger
