Author Topic: yellow 71 cuda should use what color primer?  (Read 2961 times)
Offline culp71
« on: August 18, 2014 - 12:42:40 PM »
hello all,
in process to begin painting a 71 cuda with a "school bus like" yellow PPG color, up this day we have never used any primer color but PPG DP50LF (gray) my question is with this yellow color should I be using a red or white primer instead of gray?
Also what color primer did factory use with for yellow base colors?
Thanks
Offline 74BlueFish
Re: yellow 71 cuda should use what color primer?
« Reply #1 on: August 18, 2014 - 01:08:25 PM »
I'm not a paint expert but I am painting my Cuda the same color as you.
I used the gray high build primer, sanded to 400 grit.
Then Base coat white, base coat yellow, then clear.
A 2 gallon kit of PPG Omni white was $134 gal, with the reducer another $30, but that makes 2 gal total.
 I figured that was cheaper than buying a white primer.
Dan
Dan
Offline dutch
« Reply #2 on: August 18, 2014 - 01:55:54 PM »
I used a gray epoxy and a darker gray high build.
( I`ll shoot you a pm later today )
*** Bart ***
Offline Rich G
« Reply #3 on: August 19, 2014 - 11:55:03 PM »
When I painted my 73 yellow I had to put on a few extra coats of paint to get good coverage. Are you going to use a primer sealer before the color? If you are check to see if they can tint that yellow.
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #4 on: August 23, 2014 - 08:33:27 PM »
I`ve never bought into the myth that primer color changes the final color hue, if you get 100% coverage with the paint the primer does not show thru. Maybe someone out there can prove me wrong?  :clueless:
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline 4 speed fish
« Reply #5 on: August 24, 2014 - 12:06:34 AM »
I would  use a white sealer.
Offline Rich G
« Reply #6 on: August 27, 2014 - 12:06:58 AM »
Primer color wont change the color it will just be easier to cover the primer. I was told by the Glassurit rep that yellow was one on the colors that is hard to get good coverage. I remember when I painted my Cuda, even though I was putting a vinyl top on I painted the roof and with 3 coats of color it looked like crap until I put on 2 more coats like the rep told me. Look great after that for what its worth.
Offline E-Body Products
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #7 on: September 03, 2014 - 12:15:56 AM »
The lighter the primer, the better. However, adequate paint coverage shouldn't really change the outcome. It's really only a big deal with candies. Then again, with candies, you should have adequate base coverage that it shouldn't matter.
Offline IB-Cuda
« Reply #9 on: September 11, 2014 - 08:24:38 PM »
Most paint supply places can mix or sell you some yellow coloring for your primer of choice. That way if you do get a chip in your paint you wont see gray primer at your chip  :bigsmile:
Offline jimynick
« Reply #10 on: September 11, 2014 - 09:56:10 PM »
:iagree:  Yep, what the man said.
« Reply #11 on: September 12, 2014 - 10:11:43 AM »
Quote
I believe all cars...no matter what color they were getting painted...got a coat of red oxide primer.
Offline dutch
« Reply #12 on: September 12, 2014 - 12:42:43 PM »
 :iagree:  here`s my ds door.... al colors and red primer   :dogpile:
*** Bart ***
