Author Topic: have questions on rear end on my 70 challenger  (Read 1123 times)
Offline stang13
« on: August 18, 2014 - 01:20:52 PM »
Hi
I am in the process of swapping out my 323 gears fir 370's and have a couple questions . I have a 70 challenger with a 440 six pack and a 727 torque flight trans . I do know that the rear is a sure grip / Posi with factory 323 gears . To order the gears I need to know what type of rear it is Dana 60  , etc ? How can I tell ?
Also will I need to change outr the entire center section or only the gears ?
Thanks
Tom
Offline stang13
Re: have questions on rear end on my 70 challenger
« Reply #1 on: August 18, 2014 - 01:22:39 PM »
Here is  a pic of the rear if this helps , the car is now assembled
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #2 on: August 18, 2014 - 01:40:57 PM »
That's a chrysler 8 3/4, you can grab a center chunk  with the gear ratio you want or just order the gears.  But u will need to know which housing you have.  Look for 489 or 742
« Last Edit: August 18, 2014 - 01:49:03 PM by moparman82 »
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline stang13
« Reply #3 on: August 18, 2014 - 01:45:31 PM »
where would the 489 or 741 be marked on the rear  ?
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
« Reply #4 on: August 18, 2014 - 01:49:22 PM »
Should be stamped on the center housing
Scott in Omaha
2019 Ram Laramie
2016 Tahoe LTZ SOLD
2016 Audi
« Reply #5 on: August 18, 2014 - 08:20:20 PM »
Cast on the side where the pinion runs , could be 4 different # 741 , 742 , 489 & one other
Offline joelson6
« Reply #6 on: August 18, 2014 - 11:57:15 PM »
hey, i have 3.73's in the 8 3/4 that's in my '74 challenger. i really like them for the street. with a 28" tire, 65 mph is around 3000 rpm. i have a 4 speed so you might be slightly higher with the 727.
Offline stang13
« Reply #7 on: August 19, 2014 - 12:06:42 PM »
 :) excellent !
Thanks everyone !!
Tom
