Author Topic: Sway Bar Install??????  (Read 1275 times)
Offline CUDA JAS
  • vroooooom!
« on: August 18, 2014 - 10:40:16 PM »
Yes I have another suspension question!!!
I need to reinstall my sway bar,  I noticed that the ring on the passenger side sway bar tab is broken, pic below:
I assume these rings are in there for a reason and should be fixed.  If so, where do I find the rings???
Jason
74 'cuda 360/727
Just call me a gearhead!
Re: Sway Bar Install??????
« Reply #1 on: August 18, 2014 - 10:42:57 PM »
there is no ring in there , could be a wear groove with the bushing beat out
Offline CUDA JAS
  • vroooooom!
« Reply #2 on: August 18, 2014 - 11:04:38 PM »
hmmm interesting, there are rings in both tabs.  I can move them in the holes.
 :clueless:
74 'cuda 360/727
« Reply #3 on: August 18, 2014 - 11:09:07 PM »
 :dunno:
Offline anlauto
« Reply #4 on: August 19, 2014 - 08:11:43 AM »
I would just weld it up and drill it out :2cents:
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #5 on: August 19, 2014 - 08:54:46 AM »
:dunno:
Must be serious.  I don't see that one from CP very often.
« Reply #6 on: August 19, 2014 - 10:23:50 AM »
I always assumed that "ring" was just part of the stamping process.  Maybe there is an insert that was pressed into the hole?  Either way, just put some welds on it and grind it back down.
Offline CUDA JAS
  • vroooooom!
« Reply #7 on: August 19, 2014 - 10:38:25 AM »
Yeah about that....the car is together, the control arms are all painted.  Oh and I don't have a welder.
I was hoping this was an easy fix...but maybe not.
Jason
74 'cuda 360/727
« Reply #8 on: August 19, 2014 - 11:30:05 AM »
Then I'd just put it together.  The bushings will compress and hold everything together.  You could mix up a little JB weld and smear it on the area.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #9 on: August 19, 2014 - 12:50:50 PM »
"Shoulda put a ring on it"....
Heh, normal wear nothing to worry about unless that area has lost significant thickness due to wear.
Offline CUDA JAS
  • vroooooom!
« Reply #10 on: August 19, 2014 - 02:19:19 PM »
Well the ring part is gone completely in that small area.
The actual mounting pad does not have any noticeable wear.
Jason
74 'cuda 360/727
