Author Topic: clutch purchase problems  (Read 2705 times)
Offline rtse
« on: July 30, 2002 - 10:42:06 PM »
 >:(  grrr.. i have been looking for a NEW clutch set for my car and have had no luck...does anyone have a good source for a 70 440 w18 spline trans...things go good till i tell the people i want new parts then there is no help for me,... is it just me??  ???..i had a reman clutch once and it gave all sorts of problems...  :(
Re:clutch purchase problems
« Reply #1 on: July 31, 2002 - 03:27:33 AM »
 I could probably get you one locally but I have no idea where you are ???
Personally I would use a McLeod pressure plate B&B or B&B Long style. Have you tried Summit??
Offline rtse
« Reply #2 on: July 31, 2002 - 09:51:29 PM »
montana here,locally i can only get the cover new all the other parts are reman i have tried sach's,centerforce,i found one on summits website a brand i am unfamiliar with....ram... i will call them up and get more info cuz the app is for 426-440 up to 69 ...thanks this is a start!  ::)
« Reply #3 on: August 01, 2002 - 02:53:54 AM »
Ram is OK  ;)
Offline Koolman
« Reply #4 on: August 01, 2002 - 08:32:32 AM »
Hi...
Ram is ok....I had it in my previous Challenger...
Never gave it time to break in and it held more than a year before it started slipping. (with ocassional track abuse)...
Just my .02 cents....
Later...
Get In, Sit Down, Shut Up and Hold On!!
Wanting to go faster....Going Broke......Taking Donations.....
Offline cuda
  • 1970 340 Cuda, pistol grip 4 speed,3:91 sure grip
« Reply #5 on: August 01, 2002 - 10:54:15 PM »
I have a 70 340 Cuda, pistol grip 4 speed.It has a Mcleod clutch and plate. I am very satisfied with it.Its a bit stiff but works well and does not burn.Check in on one of these maybe.Good luck
Offline rtse
« Reply #6 on: August 02, 2002 - 08:54:27 AM »
thanks! i ordered the ram,.....  :)
