Author Topic: Masking tape  (Read 678 times)
Offline Giveitawack
    • ebay
Masking tape
« on: August 19, 2014 - 02:12:10 PM »
Painted the new repro grille
The de-masking produced quite an impressive pile of tape
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
Re: Masking tape
« Reply #1 on: August 19, 2014 - 02:38:39 PM »
 :clapping: Which paints did you use and are you happy with the results?
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline Giveitawack
    • ebay
Re: Masking tape
« Reply #2 on: August 19, 2014 - 03:08:20 PM »
I think it turned out OK.
First rubbed down the glossy surface with a fine scotch brite. Worked in circular motions to avoid scratches.
Then spray can plastic primer (Hagmans)
Then a coat of structure. Also spray can. Spray light coats from a distance. If it's put on too heavy the structure won't form.
Then gunned a water based silver metallic. Regular exterior paint.
Also gunned a solvent based 2 comp gloss clear.
The structure is clearly visible through the clear but the glossy clear makes bugs much easier to wash off.
« Last Edit: August 21, 2014 - 03:44:18 AM by Giveitawack »
Offline roadman5312
Re: Masking tape
« Reply #3 on: August 19, 2014 - 03:31:32 PM »
 :clapping:  Looks awesome, great work.   :cooldancing:
Offline dutch
Re: Masking tape
« Reply #4 on: August 19, 2014 - 04:14:36 PM »
 :bigshades:
*** Bart ***
Offline roadman5312
Re: Masking tape
« Reply #5 on: August 19, 2014 - 04:32:12 PM »
Ya know the "Pile O Tape" would make a very impressive center piece for the dining room table. Wife would love it I bet.  :roflsmiley: :smilielol: :lol:
Offline Giveitawack
    • ebay
Re: Masking tape
« Reply #6 on: August 20, 2014 - 01:43:20 AM »
Yeah. Some conversation piece  :bigsmile:
