Author Topic: Starter plate or shim?  (Read 1535 times)
Offline arcticmopar
  • Yukon Canada
« on: August 21, 2014 - 01:50:58 PM »
Hey guys...this big dummy left out the little metal plate or shim  in between the block and the bellhousing on my B/RB and 727. So how important is this? Do I get to seperate the block and tranny enough to slip this in ?
RUNS WHITH SISSORS!  and  DIGITALY CHALLENGED!
Offline HP_Cuda
  • Mopar or No Car!
Re: Starter plate or shim?
« Reply #1 on: August 21, 2014 - 02:02:47 PM »
It's not actually that bad. I took my starter back out, slide it in and put her back together.
All this with headers in place but it really helped that I had the mini-starter to begin with.
B
Offline arcticmopar
  • Yukon Canada
« Reply #2 on: August 21, 2014 - 03:36:53 PM »
Well looks like I get to try and seperate the block and bellhousing, at least a little bit anyway wedge it in there. Thanks.
Offline roadman5312
« Reply #3 on: August 21, 2014 - 03:41:30 PM »
Thank god, it was going to keep me awake all night   :roflsmiley: All kidding aside if there was any gap where it had been, needs to be in there.  :cheers:
Offline arcticmopar
  • Yukon Canada
« Reply #4 on: August 21, 2014 - 04:14:41 PM »
Thats just it there is no gap with the new block or any type of indent...in the original 383 either, so it will seem to make the block/bellhousing uneven. :clueless: But since it was there before it will be again.
Offline roadman5312
« Reply #5 on: August 21, 2014 - 04:21:53 PM »
Hmmm, that doesn't sound right. Maybe it goes between starter and block/bellhousing.
Offline arcticmopar
  • Yukon Canada
« Reply #6 on: August 21, 2014 - 05:34:37 PM »
Yes it goes around the nose of the starter but it's also wedged in between the block and bellhousing. If I remeber correctly and if my setup was correct, it would kind of pivot on one of the two bolts between block and bell then the starter fits thru it and bolted in place. Of course all bets are of if this old girl was put together wrong 25 plus yaers ago. :biggrin:
Offline CudamanTom
« Reply #7 on: August 21, 2014 - 05:58:21 PM »
When putting that plate in, take a close look to make sure the block and bellhousing do not have a gap because of that plate. They should set flush together before tightening.
I'll be honest. My 440 didn't have one of those plates. No problems as of yet and I've been cranking/starting her all summer.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
« Reply #8 on: August 21, 2014 - 07:43:08 PM »
It is more of a dust cover to keep crap out of the belhousing area , then block is machined to clear the plate so you do not have to separate the block & bell to install it , slide it over the stud & it should swing into place , bolt the stater back in & go
Offline arcticmopar
  • Yukon Canada
« Reply #9 on: August 21, 2014 - 08:26:57 PM »
Thanks Chryco, thats what I thought and either I was doing it wrong ( again) or the Block wasnt machined for it. Will try again this weekend and see.
