Author Topic: Backspacing for 8.5 rim on back of E-body?  (Read 1318 times)
Offline carcrazyguy
« on: August 22, 2014 - 03:43:02 PM »
What would be the correct backspace for an 8.5 inch rim on the back of a stock suspension/brakes 73 Barracuda with an 8 3/4?
Would this work?
fronts  15x7  - 3 5/16 backspace (3 1/2 center hub bore)
rear 15x8.5 - 4 7/8 backspace (3 1/2 center hub bore)
Offline blown motor
Re: Backspacing for 8.5 rim on back of E-body?
« Reply #1 on: August 22, 2014 - 04:16:27 PM »
An 8" rim is recommended with a 4 1/2 backspace so you should be good. Your fronts will be fine. What size meats are you putting on the back?
Offline Cruzin
  • I love YaBB 1 Gold!
« Reply #2 on: August 22, 2014 - 06:37:13 PM »
What rims are these?  15x 8" is a common width.  8.5" is not a common size.  Make sure you are measuring bead seat to bead seat (check both sizes of your wheels) and you are not measuring from the flange of the rim.
http://www.ccwheel.com/technical-measurements.php
Offline carcrazyguy
« Reply #3 on: August 22, 2014 - 06:38:11 PM »
I was planning on using 215/65/15 fronts that I have had from a previous project.  Rear tires, probably 255/60/15.  I am working on a "barn find" project and was planning to use aluminum slots but they are uni-lug. So I located some used centerline auto drags. It is a low budget, for fun project. Basically will look like it was parked in a barn in the late 70's, early 80's.
Offline Cruzin
« Reply #4 on: August 22, 2014 - 06:52:02 PM »
Very cool....
Offline blown motor
« Reply #5 on: August 22, 2014 - 06:54:39 PM »
Same tire size I have both front and back. Should work fine.
Offline carcrazyguy
« Reply #6 on: August 22, 2014 - 06:59:09 PM »
What wheel sizes are you running?
Offline blown motor
« Reply #7 on: August 23, 2014 - 07:53:09 AM »
7x15 front, 8x15 rear. Both have 3 3/4 backspace. The rears are too close to the outside of the wheelwell but with a 4 1/2 (7/16) backspace you'll be good to  :burnout:
