Author Topic: That pesky amp gauge  (Read 3416 times)
Offline roadman5312
« on: August 23, 2014 - 01:52:40 PM »
I got to thinking about a 65 Comet I worked on last year. The main power wire did not attach to the gauge, it passed thru a loop on the back of the gauge( I'm trying to find a picture), I believe many early Fords were this way. I wonder if the Cuda?Challenger gauges could be simply modified to work this way.  :clueless: :dunno: Any ideas ?
Offline roadman5312
Re: That pesky amp gauge
« Reply #1 on: August 23, 2014 - 02:07:30 PM »
This is the back of a 64 Comet amp gauge, no wires attach, the main power wire just goes thru the loop. I'm going to do some experimenting.
Offline RCCDrew
« Reply #2 on: August 23, 2014 - 02:55:01 PM »
Maybe put the face and needle of your ammeter on that gauge?
Offline roadman5312
« Reply #3 on: August 23, 2014 - 03:08:26 PM »
Well here's my first test. This is the back side of a 50 Chevy pickup gauge set. I made a loop and connected both sides of the amp meter. Then I ran a length of wire thru it and shorted that wire on the positive/neg sides of a battery briefly. The needle jumps  :droolingbounce:, . Now for accuracy  :clueless: Ok I'm sure the loop will need to be made of a wide (3/8 maybe) piece of copper, which could probably be fashioned from a piece of copper tubing. I'm going to keep working on this, it could be a really inexpensive fix for all Mopars with the amp gauge problem.
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #4 on: August 23, 2014 - 05:52:29 PM »
Amp Clamp...
They come in AC and DC models. This is just one example but I'm guessing it's the same idea as your "Comet" amp gauge.
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Offline ChallengerHK
« Reply #5 on: August 24, 2014 - 04:06:09 AM »
Personally, I'd still be concerned about passing all the current the car produces through the firewall and back out again. I think the voltmeter conversion is a better way to go  :2cents:
- Han Solo, Star Wars
« Reply #6 on: August 24, 2014 - 08:35:50 AM »
In the years just before changing to voltmeters, Ford and GM amp gauges were a shunt arrangement. The ammeter circuit only carried about 5-10% of the total amperage. So, just to use round numbers, if the ammeter saw 1 amp, the actual system (shunt plus main) current was 10 amps.
Just something to keep in mind if your numbers seem off a lot when you are checking accuracy.
Offline roadman5312
« Reply #7 on: August 24, 2014 - 10:40:52 AM »
Thanks for the info dodj, I'm going to be pursuing this and trying to make it work. Also will be working on eliminating the main power wire bulkhead connector and running the wire straight thru.
« Reply #8 on: August 24, 2014 - 12:12:20 PM »
just a thought... I wonder if instead of just one wire through the loop if you made multiple passes(looping the wire) if you could achieve a more accurate reading.
Offline duodec
« Reply #9 on: August 24, 2014 - 03:09:46 PM »
Some years ago I asked about using an inductive ammeter gauge (SnapOn and others have sold them, and panel meters are also available) and adapting the mechanism to the Mopar gauge.  I don't recall getting much response but I'd really prefer to keep an ammeter, so still looking at doing that.  I found a 75 amp Cornwell inductive panel gauge but my rally ammeter is buried in storage so haven't been able to try anything yet.
The bulkhead connector can be bypassed easily enough to handle the power.  The Comet gauge looked interesting but I'd bet it doesn't have the capacity.  Inductive gauges and the shunt type seem to be available up to 150 amps pretty readily.
« Reply #10 on: August 24, 2014 - 04:52:51 PM »
Looping the wire changes the ratio.
Two times the magnetic field equals two times the deflection of the inductive meter. If there was one amp flowing and there were two loops of wire, the gauge would read as if there was two amps flowing.
Offline roadman5312
« Reply #11 on: August 24, 2014 - 05:04:31 PM »
Basically to begin with I just want to see if I can make it work, your either charging or discharging. Then compare to a volt meter hooked up, turn on lights, A/C, etc and maybe fine tune. Just a spare time thing.
« Reply #12 on: August 24, 2014 - 09:23:50 PM »
Interesting!  :popcorn:
