I know I have been asking for a lot of help over the past few years. This is what I have been able to make with a lot of hard work, time and cubic money. I could have not done it without the support of this community. Thank you all.
This is my version of what I wanted in a Cuda body. I know some of you won't like it. I hope many of you do. But, it is mine, so I get what I want.
It is a chrysler blue, not correct for the year. It is a 318 2 bbl car, and only the body numbers match. I don't care about that anymore. It now sports a 440 stroked to 520 cu.in. with a factory Edelbrock aluminum 6 bbl intake with original carb massaged with pro form jet plates. Dynoed at 557 hp, 638 ft.tq on pump gas. Full TTi exhaust. XV Motorsport Level 1 suspension, Afco adjustable shocks, Adco sway bars, PRB brake 12.5 in rotors front and rear. Hydroboost brake booster. Hotchkis upper control arms, and end links. Subframe connectors, under radiator brace, and US cartool shock tower braces. Transmission is a GM 4l60e 4 speed auto with a trans control unit, and programable shift points. TSW snetterton 18" wheels with Vredestein tires. Factory gauges customized with oil pressure gauge, and extra numbers for temperature. Seats are stock appearing, but have been bolstered and the stock skins altered to match the foam. I am sure there is more that I left out.
Thanks again for all the help and support. I am sure to be here asking for more help as I get things sorted out.
