Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
70 Steering column
« previous
next »
Print
Pages: [
1
Author
Topic: 70 Steering column (Read 669 times)
HemiOrange70
Resident
70 Steering column
on:
August 24, 2014 - 05:04:05 PM »
I have a floor shift automatic 70 Challenger. I have a 71 steering column with the finger activated key release. I want to put a proper 70 column in it. Do I need any other parts except the complete column fo rthe lock out to work?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: 70 Steering column
Reply #1 on:
August 24, 2014 - 05:11:16 PM »
The lock out was a set of linkage tied to the trans to pivot the column it mounts with a cross shaft from the trans to frame , you may want to re-think this the 71 is better
Logged
swede-cuda
Jr. Member
Reply #2 on:
August 25, 2014 - 04:21:14 PM »
:wave:i Think brewers sells repro lockout kits if you go the -70 way
Logged
HemiOrange70
Resident
Reply #3 on:
August 27, 2014 - 12:34:59 AM »
So a 70 column will not work if the linkage isn't installed, or just the lock out won't work?
Logged
swede-cuda
Jr. Member
Reply #4 on:
August 27, 2014 - 01:14:25 PM »
Quote from: HemiOrange70 on August 27, 2014 - 12:34:59 AM
:bigsmile:it will work
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #5 on:
August 27, 2014 - 11:58:53 PM »
70 works fine , without the linkage you will have to manually rotate the column to return the key to the lock position though
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
70 Steering column
