Author Topic: 72 chally factory 4 speed,,,340 plant  (Read 709 times)
Offline 71cudafish
« on: August 24, 2014 - 09:57:02 PM »
any body know how much gear oil she takes  1972 chally 4 spd  ?  and a Q ,,,, is it same trans mopar used on big blocks?????? :working: :wavingflag:
Offline bigblue73
Re: 72 chally factory 4 speed,,,340 plant
« Reply #1 on: August 25, 2014 - 09:35:39 AM »
There are two versions - actually three but the Overdrive unit is basicially a gear swap internally to the transmission.  The major difference are 18 spline input shaft for most big blocks and the 23 spline for the rest.  Iron cased - heavy (insert cuss word here) to lift whil on your back.  The easist way that I have filled is just to the bottom of the drain plug.  I want to say around 2 1/2 quarts.
Offline Sleepychallenger
« Reply #2 on: August 25, 2014 - 10:29:14 AM »
i thought that the 18 spline was mostly only for Hemis?
Offline anlauto
« Reply #3 on: August 25, 2014 - 11:01:54 AM »
Most big block 383's and some 440's used a 23 spline. Hemis and 440+6's used 18 spline
« Reply #4 on: August 25, 2014 - 11:16:24 AM »
:thumbsup: thanks for clarifying
« Reply #5 on: August 25, 2014 - 11:58:37 AM »
4 qts of GL4 gear oil , GL5 is too slippery for the syncros to work properly
