Yes already have coupling kit, as planning to change steering box soon, this is what prompted me to look at the bottom of the column. The wire retainer around the outside of the column tube in Topcat's phots, what does that hold in normally, as I have the slots for it but no wire clip ?
So if there is only one top bearing on the steering shaft, what stops it from flopping around inside the column at the bottom ?
While I'm on the steering box subject, does anyone have experience of the fast ratio Borgeson box & what are your thoughts if any, as opposed to changing pitman & idler arms to fast versions ?
cheers........
