Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
72 chally 83/4 ma mopar rear end,,,,parts # verify
« previous
next »
Print
Pages: [
1
Author
Topic: 72 chally 83/4 ma mopar rear end,,,,parts # verify (Read 551 times)
71cudafish
Jr. Member
on:
August 27, 2014 - 10:28:37 PM »
OK fellow mopar dudes is this the correct outer axel seal?
8695S,,,,,also felpro 55032 for 5 bolt gasket,,,???
axel seal I think is a TIMKEN #,,,,,,THANKS TO ALL FOR YOUR HELP
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: 72 chally 83/4 ma mopar rear end,,,,parts # verify
Reply #1 on:
August 27, 2014 - 11:39:35 PM »
I assume you are actually changing the inner seal inside the housing tube not the outer seal behind the pressed on Brg ?
8695s is correct for the inner seals
Foam gasket is 55032
steel gasket is also available from Fel Pro but I don't have that #
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
